white plug under dash?
Postby watson0720 » Sun Feb 07, 2010 4:10 am
i was messing around yesterday under my dash trying to hook up a brake controller, well i found a constant source of power in that white plug, me being the dumb butt i accidently hooked the ground up to it and it popped and now there is no power to it and ive checked all my fuses, everything in the truck works, but i just wanna make sure i didn't mess something up when i did that.
watson0720
Postby PToombs » Sun Feb 07, 2010 6:31 pm
Maybe you blew a fusible link. I'm not sure what white plug youa re referring to, but if the fuses are all good, it has to be a link.
Postby watson0720 » Sun Feb 07, 2010 11:26 pm
and where would i find the fusible link to it at?
watson0720
Postby dpuckett » Mon Feb 08, 2010 10:03 am
Inner driver's side fender, just ahead of the intake heater relay towers.
DP
Postby new dad » Mon Feb 08, 2010 10:25 am
a fusible link is usually about a six to eight inch piece of wire that is usually a 24 ga. wire inline.
98 3500, 5sp, dpp 90's, 10 plate, 4k springs, sb fe. totalled
90 d250 727, stock for now, coming soon: trans swap from a '95 2nd gen, 366 spring, m&h m5, custom crossover plumbed for a little w/m and n2o
new dad
Postby redneckroot » Mon Feb 08, 2010 1:32 pm
Where was this plug exactly?
redneckroot
Postby watson0720 » Tue Feb 09, 2010 8:29 pm
it's a big white plug right next to the radio, if you are laying on your back looking up into the underbelly of the dash, it only had one hot wire, but several pins.
watson0720
Re: white plug under dash?
Postby huntinguy » Thu Mar 18, 2010 5:43 pm
I notest that plug when I was under my dash today. I don't know what it's for. :scratch:
89 non-I/C W-250, flatbed. 4" turbo back. Ground fuel pin, AFC tuning.
huntinguy
