No spark on my 92 cummins, coil???
Postby dodgetkboy78 » Sun Mar 14, 2010 12:13 pm
Now that I got your attention. HAHAHAHA :P :alien: The responses should be good.....
I have a tach for my 92, an ISSPRO, and a crank sensor pickup coil thingie... Isn't there a wire somewhere on the IC trucks to hook a tack up? Or do I need the sensor???
Not sure why I need it, other than I have it.
92 D350 CC Smokes, leaks, stinks, rattles, and hops with 723,000 miles. Aux cab heater, little bed behind the seat, lots of chicken lights, stacks, Tims cooler tubes, Pacbrake, heavy EX springs, turned in screw, ground pin, bottomed wheel, on board air compressor, aux fuel tank, and an RTO610 roadranger.
dodgetkboy78
Re: No spark on my 92 cummins, coil???
Postby BobS » Sun Mar 14, 2010 1:27 pm
INTERCOOLED does NOT apply as my 91.5 does not have this connector. Keywords are "voltage regulator on firewall" do not have this harness provision.
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
Postby dodgetkboy78 » Sun Mar 14, 2010 2:44 pm
OK, now, I hooked it up, Ground to -, power to the + on the other side of the resistor thing, and the white signal wire to the S, and the tach dont work. Anyone know where the signal wire gets it's signal??? Or any tricks? Maybe I do need to just use the sensor....... IDK
dodgetkboy78
Postby BobS » Sun Mar 14, 2010 3:42 pm
The OEM factory tachometer plug offers the following:
- 18ga Black = +12vdc for gage lights [I believe it is fed from the light switch]
- 20ga Orange = 12vdc Common
- 18ga Red = Switched +12vdc
- 20ga Grey w/light blue tracer = Tachometer Signal From PCM
BobS
89 D350 Stock
BobS
Postby dodgetkboy78 » Sun Mar 14, 2010 3:57 pm
It's hooked up right, how do youtest the signal? I'm not sure I'm getting one.
dodgetkboy78
Postby BobS » Sun Mar 14, 2010 4:46 pm
BobS
89 D350 Stock
BobS
Postby Tintacker » Sun Mar 14, 2010 4:56 pm
dodgetkboy78 wrote:It's hooked up right, how do youtest the signal? I'm not sure I'm getting one.
What model isspro did you buy? I'm having the exact same problem. :bh:
I bought the pickup kit also, I'm just not looking forward to gluing tiny magnets to the balancer and mounting another pickup.
ECM and CPS are 6 months old.
SOLD: :( '92 W250 LE auto PDR 190's, 3200 spring, Skyjacker 2" front springs with Bilstein 5100s
'01 2500 QC/SB 4X4 6sp, camper puller
Tintacker
Postby dpuckett » Sun Apr 04, 2010 10:32 pm
If you have a 92 or 93, ISSPRO sells an adaptor kit with the tach to use the OEM pickup signal. There is a diode or something in the ISSPRO harness that does something to the signal.
Some ISSPRO gauges dont need the harness- if you have a flat faced gauge, you need it; if it's a bubble faced gauge, you dont. Or that's what I've gathered in my readings.
Why does the manual mention a red wire, when there is none?
