Electrical Problem..Need help..1992 Dodge 2500 ctd
Postby Veggiesel » Sun Jun 03, 2007 7:00 pm
My electrical system does strange things such as the cruise control works sometimes, the clock light flases when I turn on my left turn signal, if I step on the brake the clock light goes off. I am not knowlegeable in these areas so if someone could guide me thru this problem, I would sure be greatful. Thanks in advance.
1992 Dodge 2500 ctd. with Frybrid System installed. I get smile miles....running on SVO.
Veggiesel
Postby wannadiesel » Mon Jun 04, 2007 3:05 pm
Install a ground strap between the engine block or head and the firewall.
Best dyno: 408/844
wannadiesel
diesel guru
Postby PToombs » Mon Jun 04, 2007 5:27 pm
Yup! Definitely a bad ground there somewhere! :cry:
Thanks
Postby Veggiesel » Mon Jun 04, 2007 7:45 pm
Thanks for the advise will run ground strap in a.m. Thanks once again...Keith :D :D :D
Veggiesel
Postby TWorline » Mon Jun 04, 2007 7:53 pm
Check the 2 grounds at the battery that attach to your core support as well. Most still have paint under the terminals.
Tim Worline
http://www.CoolerTubz.com/
TWorline
