wait light flickers and now no charging? help!!
Postby imfixinmopars » Tue Jun 05, 2007 4:37 am
the grid system was working really good until a few days ago.the light started flickering along w/ the h2o in fuel light,then didnt come on at all.some times on a cold start the light would stay on for a while too. now this am no lights,and no charge,low voltage on the gauge. what should i ck out on this beauty,92 dually 12v,of course!
93 excab stinker 2wd/5spd
03 duramax 4x4
mopars buy the dozen,lol
imfixinmopars
Postby CAJUN 93 » Tue Jun 05, 2007 8:07 am
hate to say it but it sounds like a pcm problem.
check the alternator by grounding a wire to one of the field terminals on the back. should go to full charge (over 16 volts!!).
check crank sensor signal and wiring. if pcm sees no crank signal it will not energize the alternator.
CAJUN 93
Postby imfixinmopars » Tue Jun 05, 2007 9:43 am
i just had the alt cked and its fine,i thought the pcm was the problem,but i might retro fit a older reg for the alt and put a mom switch on the grid.thanks for the reply!
03 duramax 4x4
imfixinmopars
Postby sid » Fri Jul 20, 2007 5:55 pm
my alternator is charging i think but the guage says the last line to the left. Is that good? where is the field terminal and the crank sensor/// is there a good manual to get?
sid
Postby sid » Sat Jul 28, 2007 5:18 pm
I just went to pick up a alternator and a peiece of paper stated to check to seee if it is the sensor try the cruise control and or the a/c. if they work then it is not the pcm,, so they say--- new to this.. i think I found my problem i hope it is a short in 5th wheel wireing. which I found. will check tomorrow it is getting dark.
sid
help
Postby sid » Sun Jul 29, 2007 5:00 pm
Alt guage is reading last line to the left, not the extreme line next to the 8.
alt was tested to be good. I turn the lights on and gauge drops a little same goes for the AC. If i continue to drive it the battery goes dead. could it be a short? is there a way to test the PCM. where is the PCM. And, is there a way to check for shorts???
Sorry for the dumb questions
Sid
sid
Postby eyoung429 » Tue Oct 16, 2007 11:07 am
Pcm is located in the fender, drivers side forward.
Have no clue on testing......try googling it. I know that mine was dead when I found out I had no lights, no cruise, no radio.....went to a wrecking yard and found one out of a '92
1991 IC D350 2wd Dually,st cab, full 4in Magnaflow exhaust, 3.73 gears, auto 518,HX35....goin' to twins!!!
member of the cable pull club
eyoung429
