another charging issue topic
Postby moparman89 » Tue May 18, 2010 3:23 pm
OK..so I know there has been other threads on this,but I'm really not finding a answer...so heres my problem. Many of you may know that I have converted a 81 crew cab with a 92 cummins 5spd...so everything got tranferred over.
MY battery is not getting charged... First off I had the alternator tested and the battery...checked out fine, both are good and working.
So how Do I know if the crank sensor is bad or not?
My AC and the CC are not plug in...would this cause a problem?
I have read about installing a voltage regulator...DO I NEED SOME KIND of Relay? IF so exactly what do I need and how do I wire up the relay?
How do I know if the problem is in the PCM or not? If the problem is not in there will it hurt to hook up the external regulator?
Thanks
moparman89
Re: another charging issue topic
Postby 921stgen » Tue May 18, 2010 5:26 pm
921stgen
Postby moparman89 » Tue May 25, 2010 7:46 pm
well I cured the problem for now..went ahead and installed a external voltage reg....and it worked..charges like a champ! Still looking for a ecm though so I can get the rest of the stuff working?
moparman89
Postby Fastback66 » Wed Jun 09, 2010 4:55 pm
I am having a similar issue on my Crew cab swap. Maybe it's not ment to be. I think I need a PCM though.
78 D-200 Crew cab LWB converted to 4wd then converted to Diesel. 366 spring, custom pin, timing to head and pump tweaked.
75 W-100 SWB step side under construction. Soon to be 318 magnum/518 auto.
66 Charger 383/auto
71 Chrysler Newport hardtop 4dr. 360/727. Need drivers side body panels if ya got some.
Fastback66
