little black box rewiring?
Postby hassy21 » Mon Jun 14, 2010 4:44 pm
My black box that goes to the low pressure line on the ac went out and seen a thread that nooblet bypassed the box? Just wondering if anybody had any diagram or info to bypass?
hassy21
Re: little black box rewiring?
Postby Tintacker » Wed Jun 16, 2010 9:04 pm
Not sure how you would bypass it and still get the A/C to cycle properly. I'd be interested to know.
You can still buy the box though, Mopar P/N 56005783, You can get it online for about $75
SOLD: :( '92 W250 LE auto PDR 190's, 3200 spring, Skyjacker 2" front springs with Bilstein 5100s
'01 2500 QC/SB 4X4 6sp, camper puller
Tintacker
Postby hassy21 » Thu Jun 17, 2010 2:59 am
We'll for right now I just put an auxiliary switch to engage and disengage the AC compessor clutch. Just bypassed the two other wires and ran the brown wire to a two way switch and grounded it to the brake release lever to get a good ground. It Is a bit of a hassle but worth it in 100 degree California weather. Especially with a 1 year old in the middle.
hassy21
Postby PToombs » Thu Jun 17, 2010 5:54 pm
What's the black box do? I don't have AC on my truck and I'm curious.
Postby Tintacker » Thu Jun 17, 2010 8:23 pm
FSM calls it the "freeze control" or "electronic temperature cycling stitch". Keeps the evaporator coil from freezing up. (works better than my '04 did!)
Hassy21, If your in a bind man I think I have a working spare around here somewhere, let me know. We can't have you overheating the young one!!
John
Tintacker
Postby oldestof11 » Fri Jun 18, 2010 3:18 pm
I thought the purpose of cycling the AC is to keep from freezing the exchanger??? I know when you put propane in to use as a coolant the pressure is too low to trip the said switch thus freezing the exchanger into a ice cube.
Postby Mark Nixon » Sun Jun 20, 2010 3:27 pm
I probably have a good used one around.
Postby Tintacker » Sun Jun 20, 2010 7:41 pm
oldestof11 wrote:I thought the purpose of cycling the AC is to keep from freezing the exchanger??? I know when you put propane in to use as a coolant the pressure is too low to trip the said switch thus freezing the exchanger into a ice cube.
You are correct. What you call the "exchanger", the shop manual calls the "evaporator".
Tintacker
