need part number
need part number
Postby meby » Wed Jun 16, 2010 5:27 am
Does anyone have the part number for the adapter/vss so that I can get my speedo to read correctly now that I have the 3:07 axle under my truck?
Thanks,
Matt
-1991 D-250 bone stock
-1997 Civic Hatchback
-Case 530 CK
-Speedex Walking Tractor.
-BCS Walking Tractor
www.ebyfarmsllc.com
meby
Re: need part number
Postby dpuckett » Wed Jun 16, 2010 8:35 am
Just get an adaptor that is the right ratio. I have posted the "precedure" for determining the ratio needed. That way, you wont get "close"- you'll get dead on accurate.
Postby meby » Wed Jun 16, 2010 11:42 am
Do you have a link to this?
Thanks,
-Case 530 CK
www.ebyfarmsllc.com
meby
Postby dpuckett » Mon Jun 21, 2010 7:19 pm
Not handy.
Plug your VSs directly into the speedo drive on the transmission. Run a known distance (i.e. 10mi down the interstate works well). Divide the number of miles driven by the number of miles showing, and that will tell you what ratio you need.
SPeedometer Service in Colorado Springs used to have good prices on adaptors.
DP
Postby meby » Tue Jun 22, 2010 5:58 am
Thanks, the gear came in this morning. All I have to do now is pick it up and put it in. :D
-Case 530 CK
www.ebyfarmsllc.com
meby
Postby meby » Fri Jul 02, 2010 11:27 am
okay. Dodge messed up and gave me the wrong one. :evil: Anywho. 10 miles on the speedo is equal to 12.9 miles on my GPS. The orginal gear had 28 teeth, the one Dodge gave had 26 teeth. By my calculations the new gear should have 22 teeth.
Is my calculation right?
-Case 530 CK
www.ebyfarmsllc.com
meby
Users browsing this forum: No registered users and 53 guests
