PToombs wrote:Not sure on the 1st one, 2nd is the cruise control plug, Jon is right on the 3rd, brown wire goes to the solenoid on the starter and red is the power going the other way. Can't remember exactly where it goes to.
And you are correct on the 4th one.
So, if my truck is already wired for CC, if I got the box for it could I just plug it in and hook it up and it work? (I've swapped in a steering column out of an LE so I already have the buttons)
93flatbed wrote:1st it tach plug I think?
I don't think it's the tach plug. I would assume the tach would have 4 wires (power, ground, tach signal, and light) FWIW I have a dash harness out of a gasser and it has that same plug taped up on it.
93flatbed wrote:Hows that truck run with no throttle cable/rod?
Amazing!! Great mileage, absolutely no smoke, egt's never even get over 300 deg!! Only problem is I think my clutch may be about to go because you have to slip it a lot when shifting into the higher gears.
The throttle cable bracket was off because I'm in the process of replacing the PS & vacuum pump.
Thanks for the help so far guys!
