Something very odd happening with turn signals
Postby Collers9640 » Mon Aug 23, 2010 5:47 pm
OK someone please explain this one. Out of the blue my turn signals stop working but my hazards still work. i already replaced the flasher as well as the dimmer switch. Out of the fuse box im getting 1.5v for the turn signals and about 4v for the flashers. I am thinking that there's not enough volts getting to the turn signal flasher to induce enough voltage on the flasher windings to close the contacts. Has anyone had this happen or better yet does anyone know how to fix this.
Collers9640
Re: Something very odd happening with turn signals
Postby dpuckett » Wed Sep 29, 2010 10:21 am
Have you swapped your known good hazard flasher into your t/s socket?
Check wiring. These are old trucks, and the smoothest of them vibrate a lot.
DP
Users browsing this forum: No registered users and 53 guests
