reverse lights
reverse lights
Postby Power Ram Man » Mon Aug 23, 2010 5:50 pm
scence i did my 5 speed swap i havent been able to get my reverse lights working the switch on the transmission is working cheaked bulbs have no power to my connectors at back of truck i am lost
92 3/4 Cummins with coverted getrag 5 speed, 4x4 PODS,3200 Gov spring,16cm housing, 4inch exhuast homemade downpipe, water meth,hx35 turbo,5 inch stainless intake with AFE filter, fuel turned up, timing bumped boost,pyro guages, Denny T fuel pin,coolertubz,piston lift pump
Power Ram Man
Re: reverse lights
Postby PToombs » Mon Aug 23, 2010 6:04 pm
How did you wire it? On the auto the outside pins are the reverse lights. If you just hooked those to the switch on the standard then you must have a bad wire.
Re: reverse lights
Postby Power Ram Man » Sat Aug 28, 2010 11:40 am
well they worked with the auto i have power going to switch and completing the circut when it is in reverse i just used to spade connectors for the wires
Power Ram Man
Re: reverse lights
Postby dpuckett » Sun Sep 19, 2010 4:47 pm
Run the wires into the cab to a toggle switch. Beats trying to crawl under there and adapt stuff to fit the manual reverse light switch.
DP
Re: reverse lights
Postby PToombs » Sun Sep 19, 2010 5:34 pm
Yeah! Puckettize it! :lol:
Re: reverse lights
Postby dpuckett » Tue Sep 21, 2010 3:44 pm
Wire in an "auxillary" set of 100W offroad lights back there, and it is a good tailgater deterrent at the flip of a switch. Just make sure the tailgater isnt a cop, first.
DP
Re: reverse lights
Postby Power Ram Man » Tue Sep 21, 2010 5:02 pm
well the power wire that my buddy hooked up is coming from the front of the engine it has power has power all the time could this be the o/d switch button.
Power Ram Man
Re: reverse lights
Postby dpuckett » Fri Sep 24, 2010 6:22 pm
The b-u light circuit has power all the time- the switch only completes the circuit when turned on, making both wires "hot".
DP
