HELP dash lights/signal light prob.
Postby ccoxva » Sun Sep 05, 2010 8:39 pm
Just noticed tonight that when you turn my l/s signal on the dash lights illuminate. When you turn the sig on with the head lights on it dont flicker it just stays on but the r/s works perfectly. Only recent changes on the truck was the install of a new cd player????
1991 N/I 250
1996 Dodge 3500 Ex. Cab Dually 19.5's
ccoxva
Re: HELP dash lights/signal light prob.
Postby ellis93 » Mon Sep 06, 2010 4:25 am
Did u use the radio plug adapter or did u cut n splice.
Postby PToombs » Mon Sep 06, 2010 5:29 pm
Check for a bad ground or bulb on the left side lights. ;)
Postby ccoxva » Tue Sep 07, 2010 4:31 am
I used an adapter.PToombs Im gonna check that this evening. Thanks.
1991 N/I 250
ccoxva
Postby ellis93 » Tue Sep 07, 2010 6:25 am
On mine there were two dimer wires that was in the adapter plugs. It may be that is the problem.
