Looking for tach wires
Postby 93DodgeCummins » Wed Oct 06, 2010 6:55 pm
Hi guy i was looking under my dash for a tach wire and i have heard there was a 4 wire plug. Here is some pictures. I dont think this is the tach wire but idk
please tell me what you guys think it is because im starting to get guages and my first priority is a tach. Thanks guys!
93 Dodge W250 4X4, Custom air intake, Diamond Eye 4 inch turbo back straight pipe exhaust, HX-35W with Banks upgrades, KDP fixed, Getrag 5 speed, Isspro Tach, pyro, fuel pressure, and boost. Raptor 150, 3200 rpm spring, Power Screw in 1 turn, aftermarket fuel pin
93DodgeCummins
Re: Looking for tach wires
Postby ellis93 » Wed Oct 06, 2010 7:14 pm
My wires are white/purple stripe and red/purple stripe. There is two of each.
Postby 93DodgeCummins » Thu Oct 07, 2010 2:29 pm
yup my wires are the same. So that is the tach wires right? if so isn't there a set up i can get from isspro for a tach? Do you have a link?
93DodgeCummins
Postby 93DodgeCummins » Thu Oct 07, 2010 2:50 pm
I wonder is this is the tach wire im looking for now?
93DodgeCummins
Postby 93DodgeCummins » Fri Oct 08, 2010 11:30 am
Which plug is the stock tach wires?
93DodgeCummins
Postby 921stgen » Mon Oct 11, 2010 4:54 pm
That looks like the right one but, the tach plug is circled in a pic on this post. But you may have to join to see thepics.
http://www.dieseltruckresource.com/dev/ ... p?t=173561
921stgen
Postby Richie O » Mon Oct 11, 2010 6:30 pm
I thought his bottom pic was it, but I wasn't sure, so I didn't answer. I know I found mine real easy when I did it.
Postby 93DodgeCummins » Tue Oct 12, 2010 5:35 am
well i was just curious bottom one is it i think. I dont know what the top pics are for. Now i just need to find a connector like that or something to wire it up
93DodgeCummins
Postby 93DodgeCummins » Mon Oct 18, 2010 8:29 pm
anyone know where i can get a connector that will work so i can wire up a isspro tach
93DodgeCummins
Postby Richie O » Tue Oct 19, 2010 5:34 pm
Just use small spade connectors.
Postby 93DodgeCummins » Thu Nov 18, 2010 9:30 pm
is there any posts on how to wire a tach up?
93DodgeCummins
Postby 921stgen » Fri Nov 19, 2010 6:28 pm
921stgen
Postby 93DodgeCummins » Mon Nov 22, 2010 6:43 am
Thanks i hope that is the correct wiring. When u guys are setting up guages where do u hook up power to them for lights and stuff? I think the pyrometer is electronic so im guessing that will probably need some kind of power source also. I could be wrong.
93DodgeCummins
Postby Richie O » Mon Nov 22, 2010 10:58 am
93DodgeCummins wrote:Thanks i hope that is the correct wiring. When u guys are setting up guages where do u hook up power to them for lights and stuff? I think the pyrometer is electronic so im guessing that will probably need some kind of power source also. I could be wrong.
That link above is something that I put on DTR so as far as I am concerned it is correct. That came directily from the tech at isspro ( Don Wendlick ). I can't remember which tach it was for as I have 2 from them. One flat face and one convex. One style takes the resistor wire and the other does not. There is a fuse in the block that is for the dash lights and it should also dim that circuit when you dim the lights. Can't remember the number fuse.
Postby 921stgen » Thu Nov 25, 2010 4:42 pm
In the fuse box I used fuse #6 power windows for the ignition and fuse #14 dash lights for the gauge lighting.
921stgen
