Tach info!
Tach info!
Postby 91_CUMMINS » Sat Oct 23, 2010 6:19 pm
So I found my tach plug in under my dash and now I wanna install a tach! How do I hook an aftermarket tach to the factory plug in???? Thanks for the help!
91 RAM 350, 75HP POD's, HX44, 600HP southbend, ARP head studs, custom intake, 4"exhaust, 3"stainless coolertubz, maxed VE, fuel pin, 3200, snow performance stage 2, boost/pyro guages, 2" lift, 33's/16's, What next?
91_CUMMINS
Re: Tach info!
Postby 921stgen » Mon Oct 25, 2010 3:29 pm
Here you go. Either a factory dealer installed tach or a tach from isspro will work with the factory plug. http://www.dieseltruckresource.com/dev/ ... p?t=173561
http://www.dieseltruckresource.com/dev/ ... ostcount=3
921stgen
