sensors
sensors
Postby jrok » Tue Nov 09, 2010 4:14 pm
Does anyone have a Diagram of all the sensors and where they are on the engine?
1990 D-250 5 speed-366-Rebuilt engine (all cummins oem replacement parts)-Rebuilt facotry injectors-Hx40-modified 24v lift pump-Performance fuel pin-True 4" exhaust turbo back-3" stainless crossover intake
jrok
Re: sensors
Postby cougar » Mon Nov 15, 2010 8:19 am
I think there are only 4.
2 air temp on the intake aft of the air horn. One is for the grid heaters, the second is for the KSB.
The oil pressure sender is below and slightly forward of the fuel filter.
The water temp is at the back of the block on the left side just below the manifold.
01 2500 "the work truck".
cougar
Re: sensors
Postby 921stgen » Wed Nov 17, 2010 3:22 pm
921stgen
