Headlight wiring?
Headlight wiring?
Postby Remps » Thu Dec 30, 2010 11:23 am
I recently direct wired full battery power to the heater fan, with a toggle switch, to get the fan to spin faster. I'd guess it spins 15-20% faster with full power. My question is, do the headlights recieve full power? Or could I get more light with direct power from the battery? The more toggle switches I got, the better it is! :mrgreen:
Re: Headlight wiring?
Postby Richie O » Thu Dec 30, 2010 11:47 am
Yup. You could also fire a relay from the headlight switch and get full power that way. On my 92 I have already put relays on stop, turn, tail, back up lights to the rear. I did this because I tow some and need the extra power for extra lights. It also keeps from burning the factory harness and switch up. I have 2 more relays mounted for the headlights ( high and low beam ) but have yet to finish the wires.
Postby ellis93 » Thu Dec 30, 2010 3:00 pm
I've got my headlights on relays and yes the plane jane lights do get brighter. I had to put the relays in becuase of the silver star headlights I had installed drawed more amps and got the switch hot fast.
Postby Remps » Thu Dec 30, 2010 4:07 pm
Would a 50 amp toggle switch be sufficent?
Postby Richie O » Thu Dec 30, 2010 5:10 pm
50 amps would run everything but the starter. :D
Postby BobS » Fri Dec 31, 2010 6:41 am
Remps wrote:Would a 50 amp toggle switch be sufficent?
That would have the potential to burn the truck to the ground if the circuit isn't fused properly.
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
Postby Remps » Fri Dec 31, 2010 10:55 am
So I should run xx fuse in between battery and toggle switch, or in between toggle switch and headlights? My fuel pump, gauges, and heater should be fused as well then? Sorry, I suck at wiring. :oops:
Postby BobS » Fri Dec 31, 2010 2:53 pm
Remps wrote:So I should run xx fuse in between battery and toggle switch, or in between toggle switch and headlights? My fuel pump, gauges, and heater should be fused as well then? Sorry, I suck at wiring. :oops:
YES, between battery and toggle switch. Get one of those weather proof in line blade types that have the flip top lid. Mount it about a foot back from the battery to eliminate the corrosive battery fumes. I usually add a bit of grease on the fuse contact blades. Weather proof the connection leads with a small bit of grease and shrink tube if you have to do a crimp connection.
BobS
89 D350 Stock
BobS
Postby 12valve350 » Thu Mar 31, 2011 11:17 pm
These relays you speak of where should i put them in the headlight circut because i plan on using silverstar lights too?
Six in a row makes 'er go, Eight in a v, theres nothin' too see!
12valve350
Postby ellis93 » Fri Apr 01, 2011 5:59 am
Postby Beattyr87 » Fri Apr 08, 2011 9:04 pm
where can you get the headlight housings to run a normal h3 or h4 bulb my truck has the light and housing as one piece
Beattyr87
