alternator amp is.....
Postby sid » Fri Jul 20, 2007 6:09 pm
91 dodge cummins:what is the amparage on the alternator? where can I get one?--- Where do I go to get the alternator tested?
sid
Postby TWorline » Fri Jul 20, 2007 7:32 pm
Not sure on the amps on the 91 but, a 92 has a 120 amp alternator. Advance Auto and Autozone both do the alternator testing, both also sell new alternators. Get one with a lifetime warranty.
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby sid » Sat Jul 21, 2007 2:24 am
do I need to remove it from the truck to do the testing or do they use that cart/machine they take to the car/truck. will it damage the truck/electronics?
sid
Postby TWorline » Sat Jul 21, 2007 4:38 am
I am not sure about them checking on the vehicle, they checked mine while it was off.
Tim Worline
TWorline
Postby RumbleFish » Sat Jul 21, 2007 12:19 pm
they can check it either on or off. off the vehicle is more accurate, but on the vehicle is alot more convenient for you. besides, they don't have a 5k dollar mobile Arbst tester for nothing.
Postby BEARKILLER » Sat Jul 28, 2007 8:48 am
While we're talking checking alternators, can they check them when they don't have pulleys attached ?? ( not on the engine, of course)
I have accumulated several that I would like to know which ones are good ones.
#4 = 1991 D-350 LE Getrag
BEARKILLER
Postby PToombs » Sat Jul 28, 2007 5:25 pm
I don't think so! The tester I saw , you put the alternator on a pin, looped the belt over, hooked up the wires and spun it. No pulley, no spinney? :(
Postby sid » Sun Sep 16, 2007 9:54 am
it was the voltage regulator. all is good now
sid
Postby dpuckett » Mon Sep 17, 2007 7:15 pm
I have not had good luck with parts store rebuilds the last 2 or 3 times I got them. I have gotten my starters and alternators rebuilt by a good local shop, usually for 20-30% less than the parts stores, and I dont have the hassle of my yearly alternator change at Advance, AutoZone, et al. What good is a free exchange if it wont last any longer than the one I took off? I have yet to have to rebuild it when the local yokels do it.
Daniel
