A/C leaking
both inside and out
A/C leaking
Postby mhuppertz » Thu Sep 13, 2018 7:19 pm
Replaced the hose set from the expansion valve to the receiver/dryer and compressor, replaced the receiver/dryer and all the seals, still leaking the freon out overnight.
I put UV leak detector in and it looks like it is leaking out the receiver/dryer fittings, even tried double gasketing them, still leaking.
I can't figure it out...
mhuppertz
Re: A/C leaking
Postby Donkey Kong » Tue Sep 18, 2018 3:22 pm
Are the flange/flare fittlings clear of any burrs, dents or scratches? What type of gasket are you using? I am used to o-rings in that connection.
Darth Cummins 93 CC W250 NV4500 HX35 350hp 37s 1.5T leafs...its stiff
Donkey Kong
Re: A/C leaking
Postby bensol64 » Thu Oct 24, 2019 12:03 am
Check also the evaporator if there's any leak.
bensol64
Re: A/C leaking
Postby ihredneck » Thu Oct 31, 2019 5:46 pm
I used o-rings and the gasket together at the evaporator for the same reason.
1999 RCSB 1500 24v NV5600
2000 VW Jetta TDI
ihredneck
Re: A/C leaking
Postby mhuppertz » Thu Oct 31, 2019 5:54 pm
That's a really good idea!
mhuppertz
Return to Body
