3rd gen rims, will they fit?
both inside and out
Postby railhor5.9 » Tue Oct 28, 2008 10:23 am
got a 93 single cab and i wana put my stock 2003 dodge 17 inch rims on it will they fit? it is a 2wd.
1993 d250,single cab short bed, sbc, 175hp p-pumped,4kgsk,370's, fass 150. hx35
1997 2500 4x4 , 913,191's,3kgsk,5x16, 3rd gen dubs.
railhor5.9
Postby rbrettctd » Tue Oct 28, 2008 2:23 pm
With 2" spacers they will.
Randy
rbrettctd
Postby 1991cummins » Tue Oct 28, 2008 4:41 pm
i dont know what had to be done, but this guy i know with a first gen used to have third gen wheels on his truck, is was an 87 3/4 ton with a cummins transplant, so i have seen something close to that done before... im sure it could be done :D good luck
1991cummins
Postby rbrettctd » Tue Oct 28, 2008 7:34 pm
I speak from experience. I have late 2nd gen wheels on my truck and they are same backspacing as 3rd gens.
Randy
rbrettctd
Postby Kroner » Thu Dec 11, 2008 6:37 pm
Where is a cheap place to get spacers?
91 D350
96 2500 2.6 Puller
07.5 3500
Kroner
Postby Diesel Nut » Mon Apr 27, 2009 7:24 pm
Ok, having done this on our shop truck, let me say its a serious PITA.
Best best would be 1 1/2" hub adapters that go from 1/2" studs to 9/16" so you can use the stock lug nuts. We went another route, tried everything we could. Problem is the front hubs use a huge knurl on the stud, and there are no aftermarket studs available. We wound up drilling out new holes and pressing in new studs. Still, we needed to use spacers. We have 2 ea 1/4" spacers there now, really need 3 for 3/4" to clear the front suspension.
So, basically, either spend the money on the adapters or buy some new wheels.
2006 Dodge 2500 4x4
1991.5 250 Reg cab - Parts Runner
1990 350 Reg cab - Wants to be fast
www.dieselnut.com
Amsoil Dealer
Diesel Nut
Return to Body
