AC box interchangeability 1985 to 93?
both inside and out
Postby artieb » Mon Nov 21, 2011 2:42 pm
Hi, I may be buying a 1985 Gas truck for the cab that does not have AC. Anything major other than swapping the heater box out and the heater / AC box in? I know older GM was a pain on account the cowl. Thanks, Artie
93 CC CTD auto 4x4 plow truck, 01 Fummins with 92 CTD, ZF-6 in northern Indiana AND a VE pumped 1.6 TD 1986 Samurai
artieb
Re: AC box interchangeability 1985 to 93?
Postby dazedandconfused » Mon Nov 21, 2011 3:04 pm
The boxes are the same diameter atleast my 83s was the same as my 93. Only thing I had to do was cut the rectangular slot for the little heater looking thing.
Postby TRENDZ » Mon Nov 21, 2011 9:06 pm
I swapped an 85 gasser "heat only" cab to my 91 a/c truck. the heater box was a direct swap, no cutting or welding. The firewall on the drivers side had a few different holes for wires etc... The biggest problem I ran into was the floor pan. The 85 truck was an auto trans. The truck it went onto had a 518 auto. The floor had to be "gently reshaped" with a large hammer. The o/d section of the trans hit the floor in a big way.
91 d350 1/2" supply lines, 2nd gen lift pump, regulator, 366, screwed, homebrewed afc pin, linkage mods, ported head, ported ex manifold, 351ve electrically controlled, 3" boost tubes, 2nd gen I/C, 4" ex, goerand
TRENDZ
Return to Body
