New Wheels and Tires
Postby collegekid » Wed Sep 28, 2011 3:02 pm
Just got new 17" Eagle Alloy Alcoa Simulators wrapped in 235/80 R17 Toyo Open Country Rubber, what ya'll think?
collegekid
Re: New Wheels and Tires
Postby cmann250 » Wed Sep 28, 2011 4:01 pm
Imho, that's the best look for duallies. I still would really like to find a non-dually set of Alcoas off an old Ford for my truck :roll:
Looks good :D
Postby dazedandconfused » Wed Sep 28, 2011 4:22 pm
I really like your truck and that bed.
Postby ellis93 » Wed Sep 28, 2011 6:50 pm
I like it ;-)
Postby Hansen01 » Wed Sep 28, 2011 7:25 pm
:thumright:
Under construction...
Hansen01
Postby collegekid » Thu Sep 29, 2011 7:24 am
Thanks guys, hopefully paint in the next couple of weeks, bright white front to back with two coats clear and bed liner on top of the flat bed and white faced LED lights
collegekid
Postby oldestof11 » Thu Sep 29, 2011 5:34 pm
:cheers: :thumleft:
Nicely done!
A trick I learned from the VW crowd. To give the trim a nice look, textured black pray paint. Doe this:
That was smooth paint. The texturing looks nice and not cheap. MAKE SURE YOU CLEAN THE MOLDING GOOD! PREP IS EVERYTHING!
The guys that do this strip the paint, heat gun, and rubbing alcohol the trim to prep it nice.
Postby truckwrench1 » Sun Oct 02, 2011 2:52 pm
is this a 2wd doesnt say on sig and is there any rubbing or fittment issues with the 17 and did you have to change the wheel studs
truckwrench1
Postby Gots_a_sol » Sun Oct 02, 2011 3:11 pm
His sig says it is a d350 so it is a 2wd.
d=2wd
w=4wd
-Joe
Gots_a_sol
Postby The_Head » Sun Oct 02, 2011 4:49 pm
Looks classy. That's the look I'd be going for if I were to get some rims.
The_Head
Postby truckwrench1 » Sun Oct 02, 2011 6:02 pm
Gots_a_sol wrote:His sig says it is a d350 so it is a 2wd.
d=2wd
w=4wd
whoops missed that
truckwrench1
Postby Tacoclaw » Sun Oct 02, 2011 8:23 pm
Looks really good.
Now you're gonna have problems like me though. I hit my nasty wheels with some acid a while ago, and they cleaned up so well that the rest of the truck looks like hell in comparison. I had to go out and wash it, then clean some of the trash out of the interior, then wash the windows. I thought it would never end. :mrgreen:
Postby collegekid » Tue Oct 04, 2011 6:15 pm
Lol, ya, the yellow coming through on the front trim is buggin me to death, is there a place to get all new exterior trim (the cheap black plastic with chrome and the fender well linings?)
Truckwrench, ya, the studs are actually mounted to adaptors that give me a ford bolt pattern and stud size, so its truely ford wheels on ford adaptors on dodge hubs
collegekid
Postby 1STGENFARMBOY » Tue Oct 04, 2011 7:30 pm
The_Head wrote:Looks classy. That's the look I'd be going for if I were to get some rims.
Meeeeeeeeeee twoooooooooo that looks awsome.
is there any way you could say what the rims set you back ? ? ?
take some of the spray can bed liner and spray the trim, it makes it look new.
Dar
Postby collegekid » Tue Oct 04, 2011 7:49 pm
I got the rims, center caps and either SS or chrome lugs (whichever I wanted) for $900
collegekid
