Cab questions.
Cab questions.
Postby 89dudney » Wed Apr 30, 2014 6:45 am
What does it take to remove the cab? I have pretty well everything removed from the firewall. Im gonna try to pull the front clip this weekend. Im starting a frame up restoration and Im gonna try to clean and paint the frame. Also, whats removing the dash take?
I like my truck more than I like 99.9 percent of people...
89dudney
Re: Cab questions.
Postby dazedandconfused » Wed Apr 30, 2014 8:50 am
Cab is just 4 bolts, unbolt steering column from rag joint and disconnect wiring/heater hoses on a standard. Dash the windshield needs to come out.
Re: Cab questions.
Postby BobS » Wed Apr 30, 2014 11:05 am
Also disconnect the brake lines at the master cylinder and the parking brake cable. Remove the hydraulic clutch slave cylinder from the bellhousing if it's still in there.
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
Re: Cab questions.
Postby CumminsPower59 » Thu May 01, 2014 5:38 pm
Don't NEED to pull the windshield to pull the dash, you can take a razor and make V shaped cuts around the bolts to access them. That's what I did.
Re: Cab questions.
Postby 89dudney » Fri May 02, 2014 6:26 am
Dads dually is like that. haha I know what your talking about doing. :lol:
89dudney
