Getrag 5 Speed swap floor hump
Postby cummins1992 » Thu Nov 13, 2014 10:26 am
When doing a 5 speed swap from an auto in a D250, do I have to change the small hump out for the large hump? Or could I get away with leaving the small hump in the floor??
cummins1992
Re: Getrag 5 Speed swap floor hump
Postby PToombs » Thu Nov 13, 2014 6:17 pm
Swap it out, the 4x4/ manual hump is wider and a little higher than the 2wd one.
Postby dpuckett » Wed Dec 17, 2014 3:31 pm
It depends on the year. My mom's 92 D350 had plenty of room under the tunnel for everything. Same with my w250. I am not going to make any claims to the humps being the same without having them side by side, but I seem to recall them being similar dimensions.
Both came factory with an auto. Both now have Getrags.
Postby CumminsPower59 » Wed Dec 31, 2014 8:26 pm
Was it a club cab by chance Daniel? They have the same "large hump", regardless of drive or transmission. Its the regular cab/auto/2wd's that have the small hump.
Postby u2slow » Sat Jan 03, 2015 2:01 am
My 84 2wd/auto Ramcharger has a large hump like all my manual trucks (2wd & 4wd). The '88 D150/auto truck I got for parts has a very small hump. Its quite possible that certain cab/body types only came with the large hump tunnel.
93 W250 Club 6BTA/5spd/3.54/Dana80/~3"lift/2gen leafs/3gen wheels/HX35/5x.012s
90 D250 6BT/5spd/3.54PwrLok
84 Ramcharger [Project} D250 6BT/5spd/3.07
... various other 75-05 mopar truck products
u2slow
Postby RumbleFish » Sat Jan 03, 2015 7:52 am
Only 2wd auto reg cabs had the small humps. Everything else had the big one.
Postby Richie O » Sat Jan 03, 2015 2:07 pm
92 and 93 all have the large hump,,,, I think.
Postby PToombs » Sat Jan 03, 2015 5:49 pm
Richie O wrote:92 and 93 all have the large hump,,,, I think.
NNNNNNNNNN! Wrong! :lol:
Postby CumminsPower59 » Sat Jan 03, 2015 8:16 pm
The cab on my 91 came from a 93 D150 auto....small hump.
Postby Richie O » Sun Jan 04, 2015 4:29 pm
I guess it was all extended cabs in 92 and 93 had the big tunnel.
Postby CumminsPower59 » Sun Jan 04, 2015 4:54 pm
That is correct.
Postby ropinfool » Sun Jan 11, 2015 4:08 pm
I have a cab from an '86 D150 auto 4x4, a cab from a '93 W250 Getrag 4x4, and my runner is a '90 D250 with Getrag. If anyone wants I can post up some pics of the transmission tunnels within the next week as well as some measurements. I believe my two 250 5 speeds are the same tunnels, but it has been a while since I compared them. *edit* I forgot all 3 are reg cabs.
1990 D250- 5 speed, reg cab, long box, boost & pyro gauge, aluminum flat deck.
ropinfool
Postby CumminsPower59 » Sun Jan 11, 2015 4:58 pm
All the same "large hump".
