Odometer quit
Odometer quit
Postby brewer » Wed Mar 18, 2015 6:09 pm
Where can I find info on how to fix it? Speedo still works.
Thanks.
brewer
Re: Odometer quit
Postby brewer » Wed Mar 18, 2015 6:21 pm
Just did a forum search and found some info.
www.speedometergears.com
www.dieseltruckresource.com
brewer
Re: Odometer quit
Postby dr_funk » Sat May 02, 2015 8:29 pm
If the speedometer is still functional, then it's probably a problem in the instrument panel.
dr_funk
Re: Odometer quit
Postby ggreenall90 » Fri May 15, 2015 10:25 pm
The odometer stopped in my 91 at around 135k miles. I pulled the cluster out and took the motor off the back of the speedo. There is a 16-tooth and I believe a 32-tooth gear. The smaller (16-tooth) gear was the culprit on mine. Bought a new gear and it's good as new! There are a lot of small parts and screws so be careful not to break anything in there. Odometergears.com is where I got my gear. Cost $25. Hope this helps.
ggreenall90
Re: Odometer quit
Postby ofelas » Sun Jun 28, 2015 2:34 pm
Just changed mine out this morning - small gear was missing a couple teeth.
Picked up the small 16 tooth and the large 20 tooth for $25 shipped for both, from Kerry Conklin of LAspeedometergear.com
He sent up graphite impregnated Delrin gears (the large gear is part of the grooved pod disc instead of being 2 piece).
I replaced both gears - no filing or fit issues - spun freely off the cluster & works like a charm.
R12 = liquid bilit
ofelas
