mirrors no longer adj? flop in the wind?
Postby DTanklage » Sat Feb 16, 2008 2:49 pm
both my trucks have the big mirrors on them
the ones that have the single bolt that goes straight up thru the 4 'legs' that all bolt to the door
and they are all pretty messed up (at the single bolt)
either tight or loose
bet some of you guys are having the same prob?
easy fix is to take the one big bolt out from the bottom (i had to burp mine out cuz they were rusted in there). the arm that the bolt goes into is stainless but the bolt isnt so it rusts and the threads get all screwed up. i drilled mine out to 7/16-14 and cut a pc of grade 12 all thread. red loctite the stud into the arm, got rid of the stupid friction washers and used ss washers instead (you also have to drill the holes in the arms to 7/16), and a ss nylock
done
pretty simple but if you need pix i can take some...
don
DTanklage
Postby PToombs » Sat Feb 16, 2008 3:12 pm
I just retapped the holes, put in stainless bolts with never seize. I also kept the plastic washers, I think you get a little more friction with them.
My .05 worth. ;)
Postby DTanklage » Sat Feb 16, 2008 6:51 pm
well, if i was the only one driving my truck i wouldnt worry about any friction, i would just lock them down.
but the guy that shares the driving chores (to the track) is about half as tall as i am
lol
so, after rethinking it, mine will have to be adj (i dont want to have to use tools to move them every time we trade seats) (wont really be trading seats, more like when i am too tired to drive anymore i am gonna pull over and climb back in the trailer and crash and he is gonna keep going that way we never stop)
don
ps - mine didnt have plastic washers...it had fibers
DTanklage
Postby DTanklage » Sat Feb 16, 2008 6:54 pm
factory rusted out set up -
DTanklage
Postby DTanklage » Sat Feb 16, 2008 6:55 pm
tried vise grips...yea right...
so i just cut it off
and drilled it out oversize (3/8 drill bit)
DTanklage
Postby DTanklage » Sat Feb 16, 2008 6:59 pm
tapped it 7/16-14
cut some 7/16 stainless all thread to length
dub nut and red loctite
DTanklage
Postby DTanklage » Sat Feb 16, 2008 7:03 pm
and wah la
drilled the factory fibers out to 7/16
DTanklage
Postby DTanklage » Sat Feb 16, 2008 7:05 pm
cleaned up the frame with some scotch brite
grabbed some ss AN washers and a ss nylock
DTanklage
Postby DTanklage » Sat Feb 16, 2008 7:06 pm
and bam -
wont have to mess with them again for 100 yrs
DTanklage
Postby DTanklage » Sat Feb 16, 2008 7:10 pm
if ya ask me they shoulda came with studs and stainless hardware in there from the factory
pete, i am sure your way works just as good
but i generally only use anti seize on stuff i am gonna be taking apart often
everything else gets nylocks
i hate lock washers with a passion
later
DTanklage
Postby PToombs » Sun Feb 17, 2008 11:00 am
Don, nice sneakers! :lol: My mirrors came of a (shhhhh) ford :shock:
The bad thing is if I want to replace the head with the same thing, it's $100 or more. My FIL gave me one he had, NIB, said it was $100 2 years ago.
You probably coulda heated that and got the bolt out. I've done it and only made a small discolored mark.
I don't adjust mine too often, usually when I whack one in the parking garage. :mad:
Postby DTanklage » Mon Feb 18, 2008 2:10 am
thanks
i didnt want to get the bolt out, a) there was so much rust and b) i think they shoulda had a 7/16 stud from the gate, (not 3/8
DTanklage
Postby cummins king » Mon Feb 18, 2008 7:18 am
a little off topic, but did dodge ever make another style mirrors for our trucks, or was it all the same
93 4X4 auto
cummins king
Postby DTanklage » Mon Feb 18, 2008 9:29 am
some of the one tons came with the big mirrors and some didnt
that, i do not understand at all...
DTanklage
Postby CAJUN 93 » Mon Feb 18, 2008 10:27 am
my 1-ton came with the same chrome mirros as my wifes 250. all trucks got them in either power or not unless something else was spec'd out on the order sheet.
i personnally think west coast style mirrors are the best for towing but man are they ugly on an unloaded truck.
daryl
CAJUN 93
