steering wheel
steering wheel
Postby coram » Sun Jan 11, 2009 8:21 am
bought truck with no horn pad, no luck finding used one. was going to change to a 92 LE, brass ring behind wheel is to large, help
91.5 W250 reg. cab 4x4,5sp, 3.54 powr-lok, 285-16s,small pump adjustments, always want'n more, 140,000
coram
Postby Philip » Sun Jan 11, 2009 9:43 am
Look this add over and see if it is the same steering wheel.
http://www.cumminsforum.com/forum/1st-g ... -iowa.html
Postby coram » Sun Jan 11, 2009 11:12 am
maybe, odd angle, looks like an LE pkg.
coram
Postby dpuckett » Sat Jan 17, 2009 7:47 pm
That is the flat bottom steering wheel. At least the line across the bottom of the spokes is flat. I had the steering wheel on my 91 break, and a 93 LE bolted right up.
Daniel
