74 crew cab conversion
Postby hassy21 » Tue Nov 16, 2010 11:33 pm
I am getting a 74 crew cab 4 by 4 and going to be converting my 90 to be a crew cab long bed. Just looking for some tips to make everything go a lot easier.
hassy21
Re: 74 crew cab conversion
Postby hassy21 » Mon Dec 13, 2010 5:32 pm
anybody have any hints that i am going to run into in the future when i swit my truck over too a crew cab?
hassy21
Postby KTA » Thu Dec 16, 2010 8:44 pm
What do you intend to do cut and lengthen the frame to make the longbed fit?
Postby Bschwarzli » Wed Feb 02, 2011 10:58 am
Look on the first gen forum of the TDR. Almost everything you would want to know in the crew cab thread.
Robert
1993 W350 Dually Crew Cab - 1997 12V, NV5600, NP205, Dana 60 F, Dana 80 R, Gear Vendors, PDR Twins, 4 link rear, so mostly stock really :)
1990 W250, NV5600, 3.07s, Gear Vendors, Super HX40, kinda stock :D
Bschwarzli
