visor
Re: visor
Postby CumminsPower59 » Fri Feb 17, 2012 7:21 pm
Mark,
I will have to take a look at those visors you have when I am out that way. One question, does it matter on them if the truck has clearance lights? Are they contured to form around them? Or do they sit far enough forward as to not interfere with them?
Thanks!
Re: visor
Postby Mark Nixon » Fri Feb 17, 2012 8:32 pm
Ike, Lund made some with cutouts to clear the cab lights, which you could carefully cut in on any of them.
It's as simple as carefully marking and cutting them out.
I believe you only need to cut notches for the 2 outboards and the 1 center inboard, but I might be wrong, need to look.
Since I have one with the cutouts, it might not be too hard to make a template.
I have one of the cutout ones on the red/white flatbed that was at Michaels last year, if you saw that one.
Re: visor
Postby CumminsPower59 » Fri Feb 17, 2012 9:00 pm
Currently, my 92 doesn't have clearance lights on it, but it will soon as I have the lights, wiring, etc to install. Marking and cutting wouldn't be too much work, as long as I have a reference to go off of. If I get one from ya, I will just match it up and mark it with a sharpie to get a rough in and fine tune it later on when I am ready to install it.
I did see that one on the flat bed when I was out there, and Andrew has a picture of it in one of his albums on "facehole" :lol:
Re: visor
Postby Mark Nixon » Fri Feb 17, 2012 9:30 pm
If I could mark the cutouts on another visor by using the visor on the flatbed as a template, it could then be used to correctly mount your cab lights.
I'm assuming you're using the factory OEM cab lights?
Re: visor
Postby CumminsPower59 » Fri Feb 17, 2012 9:34 pm
Correct. I have a guide sheet with measurements as to where to correctly place the lights. Since we are on the subject, where does the wiring for said lights plug in?
Re: visor
Postby Mark Nixon » Fri Feb 17, 2012 9:44 pm
There's a female bullet connector that has a black wire with a yellow stripe that hangs off the headlamp switch.
It's kinda' located in the general area of the driver's side 'A' pillar.
Re: visor
Postby CumminsPower59 » Fri Feb 17, 2012 9:50 pm
That must be the one, I seen it before when I was in there a while back, didn't even think of what it was for... :lol:
Thanks Mark!
Re: visor
Postby bmoeller » Sun Mar 04, 2012 8:59 am
Mark, how much for one for my e/c truck? I can wait til Michael's and get it from you there.......
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Re: visor
Postby Mark Nixon » Sun Mar 04, 2012 9:05 am
$100.
Any particular COLOR you are looking for?
I might have it. :lol:
Re: visor
Postby bmoeller » Sat Mar 17, 2012 9:21 pm
Works for me.
Have paint gun, will travel. :lol:
bmoeller
