Hansen's build thread
Re: Hansen's build thread
Postby DodgeFreak » Sun Apr 06, 2014 5:20 pm
Hey, I've got a 2nd gen IC, kinda...lol its in Oklahoma at my cousins and I haven't laid my hands or eyes on it. so I'm hoping to have it before June I'll have him ship it up if I don't see him sometime soon. If you're still interested in it.
Postby DodgeFreak » Tue May 13, 2014 8:47 pm
I don't think ill have it until after the 1st Gen meet....
Postby Hansen01 » Fri Aug 29, 2014 6:42 pm
Hey guys!, I have an odd electrical issue on my pickup that I have been looking at for a while now, my fuel gauge and my oil pressure gauges don't work. I have grounded the gauge and it works, I have swapped sending units on the tank and nothing gets the gauge to read past empty unless I ground it out. I have also switched out the whole gauge cluster and it didn't change anything. there is no voltage according to a test light anywhere but when you use a multimeter, if I remember right, there was like 2 or 3 volts up at the plugs that go down to the sending unit.
Another thing I did was cut all the wires (behind the pigtail that goes to the sending unit) that used to run my tail lights and whatnots. tried grounding all of those wires to see if maybe one was spose to be a ground for the sender but no luck....
Im stumped and tired of electrical, :roll:
Under construction...
Hansen01
Postby PToombs » Sat Aug 30, 2014 6:35 pm
Sounds like a bad ground someplace.
Postby Hansen01 » Mon Sep 01, 2014 4:39 pm
Anyideas on the ground thing? Core support, behind the head, on the driver side fender, one somewhere on the back half of the frame
Hansen01
Postby CumminsPower59 » Tue Sep 02, 2014 5:39 am
Check the one behind the radio?
Postby Hansen01 » Tue Sep 02, 2014 7:38 pm
I dont think its there, i guess that would make sense i will have to check that this thursday, Thank you
Hansen01
Postby Hansen01 » Sun Sep 07, 2014 4:05 pm
Well I looked at the ground on the radio and it was off, so thanks for that lol, but I finally figured outthe problem with myfuel gauge, I just cut the ground wire at the tank and spliced in another and ran out to the frame and boom, now I got half a tank 8)
I'm assuming I'll have to do the same thing with my oil pressure gauge
Hansen01
Postby PToombs » Sun Sep 07, 2014 5:19 pm
The oil pressure sender itself may be bad, It's a common thing with these trucks. 1st look and see if it's leaking, unplug it and look in the terminal. If it's oily replace the sender, or just replace it anyways and see if that fixes it.
Postby Hansen01 » Mon Sep 08, 2014 6:34 pm
I probably will replace it first, wasn't nearly as upset that the oil pressure gauge didnt work as I was about the fuel gauge lol
anyone have any good experience with oil pressure sensors? Last one i bought from napa a couple years ago leaked from the plug within a week :lol:
P.S. i hate my body guy and dont wanna talk about that :lol:
I spose i could get a video of it running to at least prove it runs tho 8)
Hansen01
Postby PToombs » Tue Sep 09, 2014 6:05 pm
You're not alone, lots of guys have a "friend" that does body work, or drop off their truck and say "do it in your spare time", and never see it again. I've come to the conclusion that it's either pay the money to get it done or do it yourself. Any thing else and the truck is cobbed or never gets done.
Postby ellis93 » Tue Sep 09, 2014 6:54 pm
PToombs wrote:You're not alone, lots of guys have a "friend" that does body work, or drop off their truck and say "do it in your spare time", and never see it again. I've come to the conclusion that it's either pay the money to get it done or do it yourself. Any thing else and the truck is cobbed or never gets done.
AMEN!!!!!!!!
Postby Hansen01 » Tue Sep 09, 2014 8:09 pm
Well he did it in 2 weeks a couple years ago, I am actually ready for him to get his sthi together now tho, i havnt really had much time to work on it anyways lately, Il grab a picture or 5 of what I been up to, was a crazy summer
Hansen01
Postby dazedandconfused » Mon Jan 19, 2015 6:58 pm
Did you ever get it back together?
Postby Hansen01 » Sat Mar 21, 2015 7:27 pm
Yes its together! Completely done now except for a few minor details that will get done someday lol
Before:
After:
Hansen01
