&@#*!-ing Deer
&@#*!-ing Deer
Postby Douglas » Thu Mar 17, 2011 8:36 am
hey-Hey!!!,
I had deer walk out in front of me this morning. Damaged passenger side running light/headlight bezel and the grill surround and the fender behind it. Fender is probably salvage-able, and it also bent the bumper a bit. The 1990 has a grill guard installed and I suspect this saved me from more extensive damage. It makes me sad to see one ov these trucks wounded so...but at least I do not have leaks in the radiator or condensor....
cheers,
Douglas
1991 D250, 727 and 16cm H1C.
Douglas
Re: &@#*!-ing Deer
Postby ellis93 » Thu Mar 17, 2011 10:02 am
Well did you at least get to keep the deer or did it run off. I had the same thing happen and that damn thing got up and ran off like nothing happened. The next one WON'T be so lucky :twisted:
Next time it'll be tenderized. :mrgreen:
Re: &@#*!-ing Deer
Postby Douglas » Thu Mar 17, 2011 11:29 am
I didn't even look for it. That is one sweet bumper assembly you've got there.
cheers,
Douglas
Douglas
Re: &@#*!-ing Deer
Postby little doug » Mon Mar 28, 2011 10:00 pm
My wife just hit her first deer in her car this winter. :( I dont have to worry in my 91...
93 W250 LE extra cab, 5 speed,warn winch, tach,piro,boost gauges. Gov.spring and fuel pin... Play truck
-91 W350 LE reg cab chassis.exxxxtended 175"wb, banks intercooler,on board air ,5 speed,... Work truck
little doug
Re: &@#*!-ing Deer
Postby KTA » Tue Mar 29, 2011 5:07 pm
A 4wd 67 Dodge. Nice!
Re: &@#*!-ing Deer
Postby RumbleFish » Tue Mar 29, 2011 6:00 pm
Looks to be a crew cab as well. More pics?
Re: &@#*!-ing Deer
Postby little doug » Wed Mar 30, 2011 9:03 pm
I started a thread...viewtopic.php?f=11&t=10156
little doug
