Door Seals
Door Seals
Postby ivel_86 » Tue Jul 12, 2011 11:38 am
Ok so I am looking at rock auto and I need to "do" the door seals and window seals on my '93 dodge. What all do I need? Cause I see like a window scarper and window track and other stuff. ALso is it better to just buy a role of the door seal cause I need to do both doors? Thanks for any info you can give guys!.
US ARMY SGT
OIF 08-09
'93 W250, 4in Sky Lacker 35in Kelly Safari, Pump turned up, Fuel Pin ground, Pyro and Boost gauges, Straight piped, Home made air cleaner assembly.
ivel_86
Re: Door Seals
Postby JustinRhodes » Wed Jul 13, 2011 4:27 am
ivel_86 wrote:Ok so I am looking at rock auto and I need to "do" the door seals and window seals on my '93 dodge. What all do I need? Cause I see like a window scarper and window track and other stuff. ALso is it better to just buy a role of the door seal cause I need to do both doors? Thanks for any info you can give guys!.
one sec bud, redneckroot gave me the links i believe. ill check and see if i still got em and edit them in here.
http://www.rustrepair.com/PARTS_PAGE.HT ... EPU.81.WEA
http://www.jimsautoparts.com/truck_weatherstripping.htm
that look like what you need?
JustinRhodes
Re: Door Seals
Postby ivel_86 » Wed Jul 13, 2011 7:01 am
wow thanks buddy thats awesome!!!
US ARMY SGT
OIF 08-09
ivel_86
Re: Door Seals
Postby dazedandconfused » Wed Jul 13, 2011 9:21 am
I need to save these. Thanks for the info. 8)
Re: Door Seals
Postby Tacoclaw » Wed Jul 13, 2011 3:53 pm
No doubt!
Thanks Justin and Root. 8)
Re: Door Seals
Postby redneckroot » Fri Jul 15, 2011 8:44 pm
Guess I need to start checking more posts. I'm helping more people without even knowing it lol.
redneckroot
