2nd gen seat mounts
2nd gen seat mounts
Postby PToombs » Sun Jul 31, 2011 5:34 pm
For the guys that have 2nd gen seats in their trucks, have any pics of the mounts?
I set one of mine in my truck today and it sits 2-3 inches too high. I was just wondering what you guys did to get them to sit correctly. It seemed to sit good, and I know I need to adjust the rear, but what did you guys do in the front?
TIA!
Re: 2nd gen seat mounts
Postby 91bluecummins » Mon Aug 01, 2011 10:43 am
i got them and used the frame off the old seat and welded the 2nd gen hinge and sliders on the old frame cause the second gen frames sit too high and i would have had to drill new holes . this way u have all your adjustability and comfort like a new truck
92 cummins W250 extenged cab (The Goat) project truck
90 cummins W350 single cab dually flat bed 5 speed, he351ve 62mm
1959 chevy Apache 4bt cummins 4 speed
91bluecummins
Postby PToombs » Mon Aug 01, 2011 5:22 pm
You used the whole frame? Stripped off the foam and fabric and used the base? Got any pics? Appreciate it!
Postby Richie O » Mon Aug 01, 2011 5:29 pm
Postby PToombs » Mon Aug 01, 2011 5:47 pm
You're going to make go over to that spam infested slow excuse for a website? You suck! :(
Postby 91bluecummins » Mon Aug 01, 2011 5:53 pm
no i used the seat as it was and threw away the frame like legs on the 2nd gen seat and welded it to the 1st gen seat frame legs. i didnt haft to do anything to the foam or the cloth. my 2nd gen seat came out of a extended cab truck which has a cup holder in the back i put it in the front of the seat on the trans hump and it works just like it would in the back. i dont know how to post any pics
91bluecummins
Postby dazedandconfused » Mon Aug 01, 2011 5:58 pm
Put the pics on photobucket and link them on here.
Postby PToombs » Tue Aug 02, 2011 6:14 pm
91 bc, that's what I meant, stripped the bench seat to the frame. The pics on CF weren't too bad. Gave me the basics on it.
Postby firstgenjunkie » Sat Aug 06, 2011 1:26 pm
Pete, thanks for bringing this up. I've had a grey seat from a 97 SLT and haven't found a good way to mount it yet. Using the 1st gen base makes so much more sense than the mess I was trying to do with spacers and brackets and crap. I hit the pick'n pull here this morning while it was a nice and cool 97 and scored one. Only had to evict a colony of mud dabbers.
I'll weld it up this next week and put my pics on here of the finished product.
Rich
1992 Dodge D350 Dually. EV2 Pyro & Boost, BHAF, Denny T Stage 2 pin, 366 spring, 4 inch exhaust and mildly tweaked pump. 2nd gen split bench, full replacement bumper/grill, and mobile comm suite.
firstgenjunkie
Postby captmatthew1 » Sat Aug 06, 2011 6:48 pm
i just did mine up like this a couple days ago. welding it to the old frame definitely works good. (unfortunately im not that good of a welder, so it doesnt look all that good.)
1992 W250 5 speed, pump maxxed, 366 spring, caravan seats, white gauges, more to come.
captmatthew1
Postby firstgenjunkie » Sun Aug 07, 2011 7:33 am
I don't have a welding rig so I'm going to a buddy's shop and he's going to fab it up for me. Did you weld the slide rails directly to the old bottom frame or use tube steel?
firstgenjunkie
Postby firstgenjunkie » Mon Aug 08, 2011 4:44 pm
Richie O wrote:http://www.cumminsforum.com/forum/89-93-non-powertrain/334450-1st-gen-semi-restoration-9.html
If you look closely at that post he didn't mount the seats on a first gen bench frame. He drilled at least four holes for the inner legs and I'm guessing four for the outer legs. Ours only have four bolts holding it to the floor pan.
firstgenjunkie
Postby PToombs » Mon Aug 08, 2011 5:46 pm
I worked on mine yesterday. I stripped my bench frame, and then measured it. Still 2 inches too high, it would be the same as the red buckets. I then played musical frames with the red bases, the 2nds, and the stocker. I decided to cut the 2nd gen bases down and use them. I'll get pics when I get a little further. The key was I need 5.5 inches from the floor to the seat base, more than that and my legs hit the wheel like the red buckets do. The 2nd gen seats that I have are 2 inches thinner than the red buckets, so it should work out good.
Postby firstgenjunkie » Wed Aug 10, 2011 5:09 am
does your steering wheel not tilt? My legs cleared with the original 2nd gen frame, but my eyes were on level with the top of the windshield. I did have the wheel tilted up all the way and I'm 6'3", so your experience my vary.
firstgenjunkie
Postby 91bluecummins » Wed Aug 10, 2011 9:46 am
im 6'0 and with the 2nd gen seat mounts my head was bout 2inches from the head liner
91bluecummins
