seats swapped...again
both inside and out
Re: seats swapped...again
Postby Mark Nixon » Fri Jun 15, 2012 8:33 am
cumminsgirl wrote:....I put the original consol back in,, which I'm sure ill regret later when I can't use those tiny cup holders :roll:
Look around on here, someone did a small write-up on how they enlarged the cupholders on their console.
It came out pretty nice, I thought.
{edit}
Found the topic by "Gots_a_sol":
viewtopic.php?f=22&t=12062&p=93848&hilit=console+cupholder#p93848
Postby dazedandconfused » Fri Jun 15, 2012 9:00 am
I would really like to find a set of low back buckets to stick in mine. Id lile to keep them tucked back like the factory bench ssat does in the cab.
Postby Farmboy92_2009 » Sat Jun 16, 2012 12:55 pm
kinda sounds like everybody has the same game plan lol....im gna try and do quite a bit of work on the 92 by then. it will have damn near a new driveline in it after this venture when michael gets her done. then the driveshafts this fall. then the carpet and interior this winter im hoping or next spring but im hoping to have the A/C, headliner, carpet, seat swap, speedometer, and sound system all complete by michaels next year.
92 - SOLD. new ride.... 96 CC LB Dually 4x4 auto - Goerend's TD Convertor & HD VB, Autometer EGT/Boost/Trans Temp, 5'' TBE 6'' tip, #100 plate, II Dragonflow 5x.016's, CAI. Sitting in the shed - DDP 042 DV's, 80'' long Trac Bars, and nice purdy Full Replacement Ranchand :) WTB - 4k GSK, 60 lb VS's, and a 64mm turbo.
Farmboy92_2009
Postby 1stgensleeper » Fri Jul 06, 2012 9:56 pm
Where did you get the seats, a junkyard? pick n pull? How much were they? I've been thinking of doing something like this in my truck. Great write up! :thumleft:
1stgensleeper
Postby montyturley28 » Thu Nov 17, 2016 11:46 am
Have you tried a center console from the late 80s early 90s fords that had thise plastic consoles? They are alot like the ram charger consoles but had deeper cup holders. Thst grey color should be relatively easy to find.
montyturley28
smoke screw?
Postby BC847 » Thu Nov 17, 2016 2:39 pm
Monty, you realize this thread is over four years old. ;)
Postby montyturley28 » Thu Nov 17, 2016 7:36 pm
Yeah saw that after I posted my comment. I'm new to all this just bought me a 83 6cylinder trying to learn some ideas on things to do.
montyturley28
smoke screw?
Return to Body
