tire clearance
tire clearance
Postby sb91ctd » Sun Oct 16, 2011 12:04 pm
Anyone know what type of lift ill need to clear 33x12.50's or 285.75's? Id like to run 3rd gen wheels with this combo. I do need new body mounts anyway and someone told me that with a small body lift would in a sence replace the need for new body mounts......correct me if im wrong im not sure if it works that way or not. On top of that all my searches have came up empty trying to find one for a 91w250. any help would be appreciated.
Thanks,
Steve
Steve
1991 W250, stock for the moment, 146,xxx , 727 with transgo shift kit, non i/c, currently being assymbled
1988 super10 4cyl 5sp
sb91ctd
Re: tire clearance
Postby cmann250 » Sun Oct 16, 2011 12:17 pm
sb91ctd wrote: I do need new body mounts anyway and someone told me that with a small body lift would in a sence replace the need for new body mounts
Yes every kit that i have seen would cover you, but i havent seen any specifically for our trucks
Re: tire clearance
Postby dazedandconfused » Sun Oct 16, 2011 12:42 pm
If you do a body lift you will need to run a borgons shaft with the universals on both sides. The normal shafts bind on the last two W150's I put body lifts on.
Re: tire clearance
Postby CumminsPower59 » Thu Oct 20, 2011 6:42 am
I am running 285's on stock wheels, it only rubs at full lock. I have had body lifts on some of my trucks throughout the years, and I am not a fan of them. For the cost and hassle with them, you could pick up a set of front 2" springs and new shocks for a little more $$$. That's if you want no rubbing. To also add to what dazedandconfused said, your gonna have to do something with your fan shroud too as the radiator is gonna be moved up some, and the fan is gonna be in the original place. So, in the long run, doing a body lift could end up costing the same as a spring lift. Or.....another option, just trim the fenders ever so slightly. Mask off a nice, smooth line, sawzall it off, and roll the edge. Unless someone has a keen eye, its barely noticeable ;)
Re: tire clearance
Postby collegekid » Thu Oct 20, 2011 6:54 am
^x2
collegekid
Re: tire clearance
Postby sb91ctd » Thu Oct 20, 2011 5:34 pm
Well I do have the lift and shocks on the way, thanks for the input I have thought about running an electric fan to eleminate rotating mass, any thoughts or suggestions on that?
Steve
sb91ctd
Re: tire clearance
Postby oldestof11 » Thu Oct 20, 2011 6:41 pm
I have good front springs (positive arch still) and great body mounts. The 33x12.5x16.5 I have rub on a 3/4 turn and flexing of the front axle.
Re: tire clearance
Postby PToombs » Fri Oct 21, 2011 5:10 pm
Jon, is that a soda can hanging on the CB antenna?
Re: tire clearance
Postby collegekid » Fri Oct 21, 2011 5:56 pm
amazing light pole position, lol and running electric fans puts extra load on our already struggling charging system, but it def can be done
collegekid
Re: tire clearance
Postby PToombs » Sat Oct 22, 2011 6:02 pm
So it is! :lol: I thought it was a remnant of a previous adventure. ;)
Re: tire clearance
Postby sb91ctd » Tue Oct 25, 2011 5:15 pm
Oldestof11 do you have a side pic just so i can get a better idea of what clearence on the sides i would be looking at?
Steve
sb91ctd
Re: tire clearance
Postby oldestof11 » Tue Oct 25, 2011 5:20 pm
I can get full on 90* ones tomorrow.
