Clipped a tree and now door is pushed back...Help
Postby audiojock » Sat Nov 26, 2011 9:49 pm
I hit a tree and wrecked the corner of my truck... Got most of it stripped down for repair, but just can't seem to get the door to shut properly. I have loosened the bottom hinge on the inside, but can't get access to the upper one in the cab.
The door needs to go down and for ward about 1/8" - 1/4".
Any help would be appreciated
audiojock
Re: Clipped a tree and now door is pushed back...Help
Postby Philip » Sun Nov 27, 2011 3:02 pm
That door is bent most likely. Where the hinges mount is very thin metal it will bend with little effort. If you have acess to a porta-power. Use the sissor setup and push the door forward.
Postby audiojock » Tue Nov 29, 2011 8:05 pm
Yes your right. I took the door off and fixed the pinched spot. closes better that before.
audiojock
