4" Exhaust
4" Exhaust
Postby Okie Smokie » Mon Jan 02, 2012 10:51 am
I am changing to a S475 and definetely need to go to 4"if not larger. I currently have 3.5"exhaust from the turbo back. The way it's routed it runs between the t-case and frame above the cross member/skid plate. I'm afraid if I run 4" it will rub/vibrate against something at that point. So I was curious if you guys were routing it differently or wrapping it? Pic's of what you're doing would be great. Thanks in advance.
I hope I posted this in the right section. Help from the mod's if not.
'93 W250 Extended Cab, P7100, F1 Spartan, Extra Air, Tim's cooler tubes
'92 D250 Reg Cab, Flat bed, 5 speed, Bone stock
'91 D250 Reg Cab, Auto, Bone stock
Okie Smokie
Re: 4" Exhaust
Postby cmann250 » Mon Jan 02, 2012 12:10 pm
Diamond eye has a kit that includes all the funny bends. It's a turbo back system, but you'll probably need a special flange for that s475. Redneckroot on here sells the kit, i'm pretty sure. It's under $300 if i remember correctly
Re: 4" Exhaust
Postby Okie Smokie » Mon Jan 02, 2012 3:13 pm
Thank you, looks like it's still routed the same way.
Okie Smokie
Re: 4" Exhaust
Postby jmd4x4 » Mon Mar 05, 2012 10:18 am
The diamond eye 4 in fits just fine in the stock location, thats what I just put on my truck. You will need a new flange for your turbo. Hope this helps.
late
jmd
jmd4x4
Re: 4" Exhaust
Postby Okie Smokie » Mon Mar 05, 2012 3:11 pm
I have the 4" diamond eye exhaust installed on my truck now. The fit and quality is great.
Thanks all,
Joe
Okie Smokie
Re: 4" Exhaust
Postby Scrambled » Tue Mar 06, 2012 11:14 am
You can call Diamond Eye and talk with them about welding in the flange you need too. I talked with them when I did my HE351 swap but, ended up turning my own flange instead because I already had their exhaust system. And, yes their 4" system fits great around the transfer case. No issues.
Scrambled
Re: 4" Exhaust
Postby KurtzN1 » Tue Mar 27, 2012 1:37 pm
Give Diamond Eye a call. The customer service there is superb and they can usually answer most of your questions.
KurtzN1
