projector headlights
Postby jacobwebb57 » Mon Jan 23, 2012 4:07 pm
http://www.ebay.com/itm/84-86-Corolla-A ... 5891e42112
anybody runing these? are they any good? if so what bulb do you have
91.5 4x4 5 speed, dennyt stage 2. ddp 50 horse injectors. glow shift boost, fuel pressure, egt, autometer tach, 60lb vavle spring, 3800 gov springs, 1 ton axles, custom intake, 4'' exaust, hx35w pump turned up 3 turns raptor pump, and 1/8 timing.. new injectors sooner or later
jacobwebb57
Re: projector headlights
Postby oldestof11 » Mon Jan 23, 2012 5:17 pm
Buy it and let us know. I have heard of these but never knew they existed. $30 seems really cheap.
Postby jacobwebb57 » Mon Jan 23, 2012 5:56 pm
i know they seem really cheep... i found some on an actual web cite diffrent brandt they are like 60 bucks and they are warrentied so i think im gonna get them insted i just feel better about it
jacobwebb57
Postby remi » Mon Jan 23, 2012 7:12 pm
and they will fit even thought they are for a yota
1992 w250, a518, fuel screw borderline runaway, denny t stage 2 fuel pin, cai,4 turbo back straight pipe to 5inch stack, 4 inch lift, 3 and 1 boost, egt, tranny temp,
remi
Postby remi » Mon Jan 23, 2012 9:48 pm
i was looking at the pics how do you install them cause i hate my old style lights
remi
Postby jacobwebb57 » Tue Jan 24, 2012 2:05 pm
it says they will fit..idk how they mount up..posibly some jury rigging? im not sure
jacobwebb57
Postby jacobwebb57 » Tue Jan 24, 2012 2:47 pm
see im scred to get these bc i see some that say projector headlights and they are like 40 50 bucks.. then i see some that say true projectors and they are like 300..and nobody wright reviews so idk
jacobwebb57
Postby BILTIT » Tue Jan 24, 2012 4:08 pm
One install here: http://www.cumminsforum.com/forum/89-93 ... stall.html
I put HID's in my dodge with conversion housings, they are great!
I used Autopal E-spec glass H4 conversion lenses.
Be sure to get GLASS lenses, not plastic.
Get the E-spec as they have a cutoff in the lens to minimize blinding on coming drivers.
Derek B.
BILTIT
Postby firstgenjunkie » Tue Jan 24, 2012 4:19 pm
The main issue with going to HIDs is to make sure you get the projector housing. Your light pattern will be all over the place with most kits and they won't meet the law. Even though Texas does not require checking the headlight patterns during a vehicle inspection the state and fed regs say:
ยง 547.3215. USE OF FEDERAL STANDARD. Unless specifically prohibited by this chapter, lighting, reflective devices, and associated equipment on a vehicle or motor vehicle must comply with:
(1) the current federal standards in 49 C.F.R. Section 571.108; or
(2) the federal standards in that section in effect, if any, at the time the vehicle or motor vehicle was manufactured.
49 CFR Sec 571.108 Standard No. 108; Lamps, reflective devices, and associated equipment.
S5. Requirements.
S5.1 Required motor vehicle lighting equipment.
S5.1.1 Except as provided in succeeding paragraphs of this S5.1.1, each vehicle shall be equipped with at least the number of lamps, reflective devices, and associated equipment specified in Tables I and III and S7, as applicable.
S4. Definitions.....
Replaceable bulb headlamp means a headlamp comprising a bonded lens and reflector assembly and one or two replaceable headlamp light sources, except that a headlamp conforming to paragraph S7.8.5.2 or paragraph S7.8.5.3 may have a lens designed to be replaceable.
Visually/optically aimable headlamp means a headlamp which is designed to be visually/optically aimable in accordance with the requirements of paragraph S7.8.5.3 of this standard.
So state law defaults to 49 CFR and reading the standards in 49 CFR Sec 571.108, HID retrofits plopped into Halogen housings would do not the beam pattern requirements for replacement lamps. So here in Texas you could get a ticket for non-adjusted headlights or failure to use the proper headlight beam. Texas DPS did state if it was an OEM retrofit then it should comply with this regulation, blah, blah blah. I'd say go for it, just make sure you headlight patterns are adjusted appropriately. I've been reading up on doing this for my wife's Odyssey van. If you really want to read more on it try these links: http://www.danielsternlighting.com/tech/bulbs/Hid/conversions/conversions.html http://www.legallights.com/ http://orca.st.usm.edu/~jmneal/tiburon/hids.htm
1992 Dodge D350 Dually. EV2 Pyro & Boost, BHAF, Denny T Stage 2 pin, 366 spring, 4 inch exhaust and mildly tweaked pump. 2nd gen split bench, full replacement bumper/grill, and mobile comm suite.
firstgenjunkie
Postby jacobwebb57 » Tue Jan 24, 2012 4:36 pm
thanks for the law info..BILTIT where did you get your lenses?
jacobwebb57
Postby jacobwebb57 » Tue Jan 24, 2012 4:42 pm
and what HIDs did you get
jacobwebb57
Postby BILTIT » Tue Jan 24, 2012 5:30 pm
Derek B.
BILTIT
Postby jacobwebb57 » Tue Jan 24, 2012 6:40 pm
thanks.. im gonna do soem lookign around and see what i can find.. i want some the housing to be black as to go with my black grill adn rims so im gonna look around.. i guess if i go with black i need a brighter HID
jacobwebb57
Postby Hansen01 » Wed Jan 25, 2012 4:39 pm
i bought some HID's from ebay to with the projector lenses, they are super bright and easy to install. i also got the 6000k's very bright white and were about 80 bucks only thing i had to do was modify the headlight bucket a tad
Under construction...
Hansen01
Postby Hansen01 » Wed Jan 25, 2012 4:44 pm
Hansen01
