picture request!
picture request!
Postby 9312v » Thu Feb 16, 2012 2:18 pm
can i get a shot of STOCK linkage for an automatic. mine has some(a lot) of play and am trying to adjust it. also the shift pattern on the column.
park is its own, then reverse. but then does it go neutral/ drive then a detent and 2/1 right?
9312v
Re: picture request!
Postby jderr664 » Sun Mar 18, 2012 10:32 am
Here's a pic of the shift pattern if that helps some.
Pic link at: https://picasaweb.google.com/jderr664/DodgeSheetmetal#5721289132982141874
Kinda hard to get a pic of the shift linkage, I'd just replace the two platic bushings that pivot on the frame and trans mount linkage on the side of the trans. that'll help!
-Jim
jderr664
Postby Dieselwrencher » Mon Mar 19, 2012 1:25 pm
Do you still need a pic of this? We just removed one from a 92 and can get a pic of it for you if you'd like.
2000 Excursion VE 24v 47RH 4x4
1976 Chevy K30 Crew Cab Short box P-pump 12v 47RH
1972 Chavy K30 P-pump 24v 47RH
1968 Corvette 5.9 47RH
Dieselwrencher
