Who makes grill block-offs?
Postby IRoss » Sun Sep 23, 2007 1:36 pm
I'm having trouble finding any in my local parts stores cataloques....anybody have any nice ones and where'd you get'em....
thanx, ian
91.5IC 4x4 5spd extra springs
valet, 190s, ,18cm, 4"ëxh.
H4 conversion w/relays
rwal mia w/prop. valve
IRoss
Postby IRoss » Sun Sep 23, 2007 2:56 pm
After doing some research on a few others sites, I have to conclude that there are absolutely none available....time to take a case of beer over to my buddy's plasma cutter....
IRoss
Postby wannadiesel » Sun Sep 23, 2007 4:04 pm
Lund makes a set of blockers for the '91 and up trucks. There's a company in Canada called Fia that makes full winter fronts.
Best dyno: 408/844
wannadiesel
diesel guru
I use a company up here Called air hawg
Postby roxxx » Sun Sep 30, 2007 6:01 pm
I use a company up here Called air hawg, and they are resonably priced. I will see if they make them for the 1st gen, i need a set too so may as well ask them . i have put them on every truck we have bought with no problems and they are a bit thicker than some of the other brands
1992 4x4 Reg cab LE 5 speed
4 Inch lift
Bilsteins shocks 5125
VE moderately molested
Dana 80
ultra wheel rims Type 164
ASA pipe BHAF 19037
Outerwears prefilter
A A nv4500
roxxx
Postby RumbleFish » Sun Sep 30, 2007 6:46 pm
I had a set of the lunds for my 91. They were a bit of a PITA when it was time to take them off (or maybe I never figured out the right way???). This guy I know made a set from some plexiglass bought from the hardware store. Painted them black, drilled holes in each corner, and used zip ties to hold them one. He had less in them than I had in the ones I bought from lund.
Postby ofcmarc » Sat Oct 20, 2007 4:51 am
I have a set of LUNDs and they work but aren't friendly to adjust dependant on the weather.
Local company up here makes some good winter fronts and / or bug screens for the summer.
http://www.alaskatent.com/products/cove ... fronts.htm
'92 W-250, Getrag, Pump Tweeked, 366 Spring, Fuel Pin Spun, 14cm W/G, 3.5in Exhaust, Pyro/Boost Gauges, Front End Leveled, 202K
ofcmarc
Postby dpuckett » Sat Oct 20, 2007 6:44 pm
By "grille block offs" do you mean winter fronts? I have considered it, IF I ever move to a cooler climate. Heck, I still need AC, though there have been more roll-the-windows-down days lately.
Daniel
I am working on the grill inserts (summer and Winter)
Postby roxxx » Mon Oct 22, 2007 10:43 pm
I have talked to few company's about it, just waiting for a reply. they make inserts for newer models hoping I can Grin my way in to getting them to water jet us some I will keep you all posted
(Edit) rolling your Window down huh dpuckett Bahhh
4 Inch lift
Dana 80
ASA pipe BHAF 19037
A A nv4500
roxxx
Postby bgilbert » Sun Nov 04, 2007 7:46 pm
www.gofia.com is what Dave mentioned. I have a winter front and bug screen from them. Nice easy to install.
Bill Gilbert
bgilbert
