Grill removal..easy?
Postby jorez » Thu Mar 29, 2012 4:31 pm
I am looking for any tips to removing the grill..haynes manual has nothing..is it as simple as see screw..unscrew..repeat? I am getting it painted next week and he wants as much as i can take off..off....and will i be "legal" to drive without a grill fo some miles??
jorez
Re: Grill removal..easy?
Postby CumminsPower59 » Thu Mar 29, 2012 7:22 pm
As far as I know, as long as you have a license plate and something that resembles a bumper, you are legal around here. I am not sure on the grille part, looks to me like a screw off/on affair...
Postby Tacoclaw » Thu Mar 29, 2012 7:44 pm
What year truck?
On the 89-90, the grill comes off in 4 parts. Headlight buckets(the marker light bulbs screw out of the back of the lens), then the crosshair piece, and finally the metal surround. They're all held in with Philips-head screws, and there's no real trick to it. Just don't lose any of them.
On the newer ones that are chromed plastic, I have no idea. I've never worked on one...
Postby CUMMINSDODGEMAN3 » Fri Mar 30, 2012 5:31 am
if its a newer plastic one there like 6 screws under hood on core support, then pull turn signals our theres one on each side there and a couple in center in the louvers an bottom.
Team Green's old hauler 05 3500 CTD 4x4 6sp 8in rize industries lift, 37 Toyo M/T's, Smarty, Edge Att, AFE intake, ATS manifold Borg Warner turbo, 5in SS MBRP
90 W350 CTD SRW big pump, big turbo, lots of fuel, 47RH billet suncoast triple disc and 20's
93 D250 CTD ext cab pump work, POD's
CUMMINSDODGEMAN3
Postby jorez » Fri Mar 30, 2012 5:45 am
Thanks all! Will get to it over the weekend!
jorez
