Arm Rest/Door Handle Came Loose
Postby Diesel » Wed Apr 11, 2012 3:18 pm
So the passenger side arm rest came loose when someone was pulling the door closed. Do I have to remove the panel to screw it back on?
1991.5 D250 Intercooled A518
Diesel
Re: Arm Rest/Door Handle Came Loose
Postby PToombs » Wed Apr 11, 2012 5:23 pm
Yup. You may want to look at it close, I think they rot out where the screws go in. After the reread, maybe the screws just pulled a little and they'll tighten back up. Good luck!
Postby Diesel » Wed Apr 11, 2012 7:44 pm
Good to know thanks. If the holes are rotted I'll bore it wide, run wire into the armrest, backfill with jb, and then drill and tap.
Diesel
