whats a good seam filler
Postby Ol_blue88 » Sun May 06, 2012 11:43 pm
I need to reseal the raingutter and the seam were the roof meets the metal above the backglass. What's a good choice of filler to use.(I plan on painting over it)
Ol_blue88
Re: whats a good seam filler
Postby ellis93 » Mon May 07, 2012 9:04 am
3M is what my body man brother-in-law uses.
Postby m880cummins » Tue May 08, 2012 3:48 pm
Most paint shops carry the 3M brushable seam sealer which is $30/qt or you can get a tube for a caulk gun for around $15
Charlie
SUNY Maritime Class of 2017!
m880cummins
Postby Ol_blue88 » Tue May 08, 2012 7:59 pm
Thanks. I was looking at either. The 3m or the Eastman 2k filler
Ol_blue88
Postby james1 » Tue May 22, 2012 2:47 pm
In 2011 I had a good local body shop repair my cab roof and drip rail. He used a 2-part epoxy product from Rubber Seal (a division of Teknol) called Self Leveling Seam Sealer MRS-7204. It's the OEM product nowadays on a number of Ford products.
http://www.rubber-seal.com/prodview.asp?prodID=2203
It certainly looks a lot smoother than the OEM Mopar stuff from 1993; chemical engineering has come a long way since then. :)
james1
