Body Moulding Restoration/Modification...
Postby CumminsPower59 » Sat May 12, 2012 8:15 am
Since most of the moulding on the 92 looked like crap, the cheesy chrome strips were peeling off and the black paint on the flares was chipping off, I figured I would to do something about it since I haven't been able to find anything aftermarket that resembled the stock stuff. I prepped them with a green scotch brite pad and bombed them with spray-can bed liner, I think it turned out pretty well :D
What do ya'll think?
Re: Body Moulding Restoration/Modification...
Postby oldestof11 » Sat May 12, 2012 9:45 am
Looking good!
A VW site had things to do to restore their body molding. 1 was heat gun to melt the old paint back into a shiny state. The other was using heat gun/alcohol to clean it and a black shoe polish.
Postby CumminsPower59 » Sat May 12, 2012 11:05 am
Thanks Jon! It was driving me nuts having the truck missing the one piece that is on the drivers side of the box in front of the wheel well. I had the original piece, but it had fallen off and looked terrible. It was bent like a bannana too, put it in our parts washer at work (hot water type) and used my straight edge and clamped it to my work bench for a day to straighten it out. I tried to remove what was left of the chrome strip, that was a pain in the arse! I said screw it and one of my buddies said spray it with bedliner, so I did. Looked good enough that I stuck it back on with some 3M tape and did the rest of the truck with it. It's not a perfect job, but from ten feet, it looks good enough!
