Drivers side window won`t roll up
Postby Diezeldriver » Sat May 12, 2012 6:50 pm
Help! My window motor fried and it will take a few days to get one in. How do I get to go up and stay up? Any suggestions?
92 W250 Club Cab, cut fuel pin, fuel screw turned up, M&H timing device, POD injectors, K&N filter, 4in exhaust from the DP back, 16cm turbine housing, Autometer Ultralite 2 guages, Suncoast 47RE transmission, Ruenel Bumpers, Best 1/4 14.51 @ 90mph.
96 2500 reg cab CTD: 60# valve springs, silverbullet, switch to lock, afc, 4k gov spring, no plate, 4in dp to 6 in stack
Diezeldriver
Re: Drivers side window won`t roll up
Postby bmoeller » Sat May 12, 2012 7:31 pm
Gonna have to pull the door apart on the inside to get at the motor.
Sure it's the motor and not a switch?
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Postby PToombs » Sun May 13, 2012 5:14 pm
Sometimes you can hold the button and whack the door and it will jar the brushes enough to run it up. Did that with my moms car for a few months. I'd keep forgetting it was bad and run it down. :x
Funny, the damn thing would go down just fine, and never up. :roll:
Postby lopez dodge » Fri May 18, 2012 6:45 am
are sure its the motor ? if the motor spins but doesnt move the window it could be just the nylon bushings in the gear box , mine did that cost .99 to fix .
thread over on dtr. has details
1991.5 ..getrag super40. 40,horse injectors,4"to 6" exhaust , bhaf 2nd gen intake,custom pin timed to the head ..1/4 14.9@93mph 5,500' with a little propane
lopez dodge
