Custom 1st gen gauge pods
Postby Bschwarzli » Mon May 14, 2012 2:54 pm
Have I ever mentioned I like gauges? :D
Well, I needed two more. I added fuel PSI and oil temp.
So that now created an issue for the 1990. Where to put them. This is what the truck looked like before:
Sooooo, out things came....
Then the pod mods came. First off the third gen roof pod. The 3 pod was modified last time. The 4 pod (also a 3rd gen unit) here is untouched and gives you an idea of how much cuttings needed.
Next, A pillar pod. It is a 86-93 Autometer unit. I picked up a second one for the crew so one is untouched and the other is hacked. Gives you an idea of the amount of cutting.
And the result!
Image[/QUOTE]
1993 W350 Dually Crew Cab - 1997 12V, NV5600, NP205, Dana 60 F, Dana 80 R, Gear Vendors, PDR Twins, 4 link rear, so mostly stock really :)
1990 W250, NV5600, 3.07s, Gear Vendors, Super HX40, kinda stock :D
Bschwarzli
Re: Custom 1st gen gauge pods
Postby PToombs » Mon May 14, 2012 4:49 pm
When are you getting your pilots license? :lol:
Robert, what holds the pod on the ceiling?
Postby dazedandconfused » Mon May 14, 2012 5:49 pm
I want to see a night shot.
Postby CumminsPower59 » Mon May 14, 2012 6:19 pm
Damn! There are more gauges in that truck than the 06 Peterbilt I use to drive!
Looks good :thumright:
Postby oldestof11 » Mon May 14, 2012 7:18 pm
Who are you and what have you done to Richies truck??? :shock:
Looks good man! :lol:
Postby Bschwarzli » Tue May 15, 2012 4:48 am
Pete
LOL.
And I drilled 4 holes into the bottom of the pod, and tapped the inner roof pan. Then placed cup washers on the screws and budda bing!
Dazed
I will see what I can do on that.
Ike:
LOL. Thanks.
Jon,
Me no touchy. :D
Bschwarzli
Postby Eric_M » Tue May 15, 2012 2:43 pm
Looks good! Is there anything you are not able to monitor?
91 D350 5spd stock a little rough around the edges and needing some work but it should drag my 87 4runner around great!
Eric_M
Postby PToombs » Tue May 15, 2012 4:53 pm
His wallet! :lol:
Postby Bschwarzli » Wed May 16, 2012 6:26 am
Eric
Oh yes! The project truck has 24 gauges. The 1990 is only at 13. I have a ways to go before that happens.
Pete
Advantage of being single. :D
Bschwarzli
Postby PToombs » Wed May 16, 2012 5:19 pm
Yup! I call that "The good ol' days"! :jumpsmile:
Postby Bschwarzli » Thu May 17, 2012 2:44 pm
You bet! Thats why I don't want to get a significant other. I like my truck too much! LMAO
Bschwarzli
Postby dazedandconfused » Thu May 17, 2012 3:07 pm
Hmm im single and still don't have 2 nickels to rub together for my truck. Of course i do have a daughter to take care of.
Postby orlnd03 » Tue Sep 08, 2015 9:44 pm
Hi, where did you get the gauge pod for the ceiling?
orlnd03
Postby DMan1198 » Fri Sep 11, 2015 8:28 pm
It would've been through autometer.
Postby t_ruffcorn » Wed Dec 23, 2015 9:55 am
orlnd03 wrote:Hi, where did you get the gauge pod for the ceiling?
Autometer part number 18018
1993 w250 280k, 5 speed, 6x13 @80lpm, BD pin, 63/68/.80, 4200 gov, fluidampr, studs, springs, pushrods, 182/214 hamilton, W/M, steedspeed, PS I/C
t_ruffcorn
