How much did a paint job run you?
Re: How much did a paint job run you?
Postby 93oneton » Thu Jan 02, 2014 11:24 am
cmann250 wrote:After doing my own paint job in August, I can say this: you can do your paint ONLY if you are content with your skill level AND if you are not in a hurry.
Otherwise, pay someone else to do it.
100% correct. When i did mine it was alot of time consuming work. I did all my body work and had a buddy spray it in his both. Way better that way.
Shit happens
93oneton
Postby matthewh » Fri Jan 03, 2014 10:26 pm
JimmieD wrote:Just curious on the paint thing. A couple of years or so ago there were several threads on various automotive forums about painting a car or truck using the small disposable foam rollers and quite a bit of finish sanding. Did anybody here ever try that? LOTS of folks swore it really worked and they were quite happy with the results, like dozens of people.
My last 1st gen I used the roller technique. Used a DA with 220 grit paper, took off the shine of the previous paint, and rolled away. I thinned the first 2 coats, to help establish a base, and start getting the color to change, then thinned just enough to get it to "flow" better. Used the white foam rollers, had a long day into it, by the time I sanded, wiped it down, and rolled the paint, had 5 coats total, came out pretty good. Biggest problem I had was changing from Silver to Air Force "Strata Blue", took more coats than I thought to get a complete color change
Granted, it was a rusty plow truck, so what parts I hadn't replaced, I sprayed with a "Rusty Metal Primer" first to help seal up the rusty spots, then rolled away.
matthewh
Postby JimmieD » Fri Jan 03, 2014 10:57 pm
Thanks for the foam-roller info, guys!
1967 Dodge D-100 Town Wagon - CPL 858 4BT, HTT Stage II/H1C 16cm/56cm turbo, '93 CTD I/C, 32K spring, minor fuel tweaks, milled head, NV4500, 1 ton springs, '72 D-200 Frt. axle w/ Air Lift bags, 4.10 Dana 60HD, F/R swaybars, Tom Woods shaft.
'90 W-350 gasser...
JimmieD
Postby joshotto94 » Mon Jan 27, 2014 8:30 pm
I do paint and body on the side and i teach it at night you get what you pay for i usually charge about 3-4 k my self that includes material and labor
joshotto94
