club cab pax seat bracket ?
Postby phatbob » Sun Jun 10, 2012 12:42 pm
hi
the pax seat bracket (the part that has the hinge) has corroded / broken on my 91 club cab, so the seat is basically not attached (so I took it out). just wondering if anyone knows of a replacement bracket or part # or aftermarket source for these brackets... no junkyards anywhere close to me... the seat is fine so I'd like to keep it but I'd be open to a swap if there was a bolt in
thanks
phatbob
Re: club cab pax seat bracket ?
Postby dazedandconfused » Sun Jun 10, 2012 1:23 pm
Next time i go to the farm ill see if i still have them out of the truck i parted a while ago.
Postby PToombs » Tue Jun 12, 2012 5:15 pm
Some guys just go to Home Depot or someplace like that and get a piano hinge to bolt in. I believe some even have bought stainless.
Postby CumminsPower59 » Wed Jun 13, 2012 5:49 am
Thats kinda what I did, took two heavy duty non drilled door hinges, measured, drilled and installed them in the stock location. Works pretty good ;)
