Extended cab short bed conversion
Postby apaches64 » Sat Jul 07, 2012 6:01 pm
Any one done a ecsb conversion? I need some wisdom on the subject if anyone has some to glean. I currently have a reg cab that squeaks, and leaks. I have a line on a reg cab, and I also have a extended cab that I can get ahold of. Is the conversion worth the trouble?
apaches64
Re: Extended cab short bed conversion
Postby CumminsPower59 » Sat Jul 07, 2012 6:16 pm
The one that I have seen online, the fellow chopped and shortened the frame so a shortbed could fit on. As for being worth the trouble...that is something you will have to decide, as eveyone will have a different opinion on if something is too much trouble.
Hope this has helped you ;)
Postby m880cummins » Fri Jul 13, 2012 6:45 am
I would think a regular cab long bed would be the same wheel base as a extended cab short bed so you could just swap the cab but I am not sure whether you would have to modify the cab to fit a different frame rail profile as the frame would turn up right behind the cab on the regular cab and an extended cab frame would have a longer drop down for the cab to fit. Its the same issue I believe as trying to put a crew cab onto an extended cab frame.
Charlie
SUNY Maritime Class of 2017!
m880cummins
Postby RumbleFish » Fri Jul 13, 2012 9:19 am
Iirc the wheelbase is different. In the neighborhood of an inch or two longer for the xcab.
Postby oldestof11 » Fri Jul 13, 2012 2:04 pm
Over on CumminsForum, a guy that goes by 9297oldram (or something like that) has an ext cab short bed.
Postby Gots_a_sol » Mon Aug 27, 2012 2:08 pm
I shortened my truck from a long bed to a short bed.
The wheelbase is right around 134" I think
-Joe
Gots_a_sol
Postby RumbleFish » Mon Aug 27, 2012 5:52 pm
wanna do that to mine???
Postby Gots_a_sol » Mon Aug 27, 2012 8:14 pm
I'm confident enough in my metal melting abilities to do my own, just not others. Too much liability involved in cutting up other peoples trucks, sorry.
This is what the left overs are after doing it. 4" off the back of the frame, ~16" out of the center, exhaust, and drive shaft.
-Joe
Gots_a_sol
Postby apaches64 » Fri Jan 24, 2014 5:45 pm
Wheel base diff=
131 rclb
133 ecsb factory half ton
apaches64
Postby FIRST GEN. JAKE » Wed Feb 19, 2014 10:19 pm
Sol what did you do about your brake lines? I got a reg cab I'm wanting to cut down myself
FIRST GEN. JAKE
Postby Gots_a_sol » Sat Feb 22, 2014 9:25 pm
The hard lines? I just looped the extra out and back above the fuel tank. If my flaring tool wasn't broken at the time, I would have shortened/re-flared them.
-Joe
Gots_a_sol
Postby FIRST GEN. JAKE » Tue Feb 25, 2014 9:44 pm
Yea the hard lines was what I was wondering about. I wonder if you could use short bed halfton lines and they fit correctly? I'm going to cut my reg cab down but I've never really messed with hard lines before
FIRST GEN. JAKE
Postby coalcowboy93 » Fri Jul 18, 2014 6:29 am
If you are taking a sclb and wanting to do a ecsb all that need to be done is the rear cab mounts need to be cut and moved back to accommodate the longer cab then it's a matter of mounting the bed an running everything I am going to be doing the same thing to my 93 sclb. Hope that helps.
coalcowboy93
Postby coalcowboy93 » Fri Jul 18, 2014 6:31 am
Never mind it I thought you were doing sclb conversion sorry about that. Can't read. Haha.
coalcowboy93
Postby Lee » Mon Feb 23, 2015 12:50 pm
Just joined when I saw this thread. I am getting ready to do this to a 92 W250. I was wondering if you took a measurement of the shoertening of the rear axle?
Lee
