buffed out
buffed out
Postby 1STGENFARMBOY » Mon Aug 06, 2012 8:10 pm
finally got started on wet sanding and buffing out my paint after a year, :roll: :roll:
it's not as perfect as i would like in a few spots, but i have been called a paint freak. :lol: :lol: :lol:
Darwin
Re: buffed out
Postby PToombs » Tue Aug 07, 2012 4:09 pm
Ya know, you suck! :tongue: You give me a feeling of inferiorty, because my paint is all orange peely looking and I don't have the time and aren't good enough to buff it out. :(
Re: buffed out
Postby BC847 » Tue Aug 07, 2012 5:09 pm
That's right sporty!
Re: buffed out
Postby 1STGENFARMBOY » Wed Aug 08, 2012 11:04 am
It ain't perfect by no means, but i use it like a truck also.
only thing is now there will be profanity flying when it gets a limb scratch. :lol:
if i can do it Pete then you can, your just to lazy to try..... :lol: :lol:
i can give some classes at S.O.P.
i been thinkin about bringin a little electric motor for a quick how to repair it class.
cause i'm shure every one of you have an electric motor on something, and those little
bastages ain't cheap anymore.
Re: buffed out
Postby dazedandconfused » Wed Aug 08, 2012 12:07 pm
looks good!
Re: buffed out
Postby 1STGENFARMBOY » Tue Aug 14, 2012 8:59 pm
got it pretty close to done this weekend.
Re: buffed out
Postby tampabayBill » Wed Aug 15, 2012 6:16 am
Looks GREAT !!
Twins coming soon!
tampabayBill
Re: buffed out
Postby PToombs » Wed Aug 15, 2012 4:23 pm
Dar, the truck looks awesome! :tongue:
Re: buffed out
Postby 1STGENFARMBOY » Tue Aug 21, 2012 9:05 pm
thanks men.
Re: buffed out
Postby ahale2772 » Thu Aug 23, 2012 3:22 pm
that is by far the best looking 1stgen I've ever seen.... bravo
Re: buffed out
Postby cmann250 » Thu Aug 23, 2012 4:33 pm
The paint looks excellent! I'll be picking your brain at Scheid and SOP about equipment and techniques.
Ever consider putting Alcoa dually rims on it?
Re: buffed out
Postby dazedandconfused » Wed Sep 05, 2012 1:57 pm
Hey Dar what brand paint did you use? Its base/clear coat right? Also what brand gun did you spray it with? It really looks great in the pics the more i look at it.
Re: buffed out
Postby ftexbassman » Wed Sep 05, 2012 8:41 pm
WOW,, shes beautiful!! nice rig
ftexbassman
Re: buffed out
Postby 1STGENFARMBOY » Thu Sep 06, 2012 5:00 am
I used nason paint it's made by dupont but without the warranty, the gun i used to shoot the clear is an old preshure cup Devillbiss, the base coat gun i used is a very cheap HVLP gun. it is base/clear. for everything to paint
primer 1 gal 3M fill and sand
sealer 1 gal ready to shoot
green 3 qts
silver 2 qts
activator for base coat 1 pnt
clear 1 gal
activator for clear 1 qt
reducer 1 gal
total including some tape and sandpaper was in the ball park of $600.00
Darwin
Re: buffed out
Postby dazedandconfused » Thu Sep 06, 2012 9:37 am
Thanks for the info.
