Did something about the interior on this thing. Don't plan to use the cab any bit longer then when the 4 door cab is finished so I just used plywood on the floor and called it good enough. Headliner and floors are Home Depot indoor/outdoor area rug 6x8 for $17. I used plastidip in a spray can for the trim and dash and it is really nice and durable. It doesn't chip but if you cut it you can peel it off. If it is damaged, when touched up the finish will morph back together and be noticeable. I used no sound proofing and find no difference in interior noise between now and before. The headliner will get 4 LED lights instead of the stock one... I am not using sun visors and will instead use a tint on the top of the windshield. It will also be fitted with a custom fabricated cab-mounted rear view mirror.
HAD TO GET RID OF BABY POOP BROWN INTERIOR!!!!
Charlie
