weak door skins
weak door skins
Postby (92)cummins » Fri Sep 07, 2012 6:33 pm
does anyone know how to beef up the door skins, i have good doors but they are flimsy
92 w350 srw flatbed
1985 D350 crew cab diesel conversion in progress
79 w200 power wagon
93 D350 drw 5spd getrag 4 door donor
90 D350 auto(fried) flatbed
93 D250 auto
(92)cummins
Re: weak door skins
Postby oldestof11 » Fri Sep 07, 2012 7:25 pm
All new car nowadays have really thin material. You lean up against one and you hear "boom bimp". If you hear to boom but not the bimp, you have a dent!
I got nothing but this quote from Mr Sound Effects.
Re: weak door skins
Postby (92)cummins » Fri Sep 07, 2012 7:38 pm
well around the handle it likes to move and on my 90 it wasn't that weak and where the window disappeares the skins will clap together when u close it
92 w350 srw flatbed
79 w200 power wagon
93 D250 auto
(92)cummins
Re: weak door skins
Postby ellis93 » Fri Sep 07, 2012 7:45 pm
I've seen my 93 do that,thats why I close the door by pushing on the area around the lock.
Re: weak door skins
Postby (92)cummins » Sat Sep 08, 2012 5:15 am
i thought i had heard of people who found a way to fix it
92 w350 srw flatbed
79 w200 power wagon
93 D250 auto
(92)cummins
Re: weak door skins
Postby cmann250 » Sat Sep 08, 2012 9:17 am
I've seen a thread over on DTR about how to beef up the doors. I haven't tried it.
Re: weak door skins
Postby (92)cummins » Sun Sep 09, 2012 6:34 am
alright ill try lookin over there
92 w350 srw flatbed
79 w200 power wagon
93 D250 auto
(92)cummins
Re: weak door skins
Postby oldestof11 » Sun Sep 09, 2012 7:06 am
That was an inner door brace.
Re: weak door skins
Postby Tacoclaw » Tue Sep 11, 2012 6:37 pm
Well, since the door panel is bolted to the inner door then any strengthening there will help out the panel. ;)
http://www.dieseltruckresource.com/dev/ ... 470p5.html
Here's one of the threads about it, it's about 2/3's of the way down the page.
Re: weak door skins
Postby (92)cummins » Sat Sep 15, 2012 7:39 am
alright looks like something like that would work
92 w350 srw flatbed
79 w200 power wagon
93 D250 auto
(92)cummins
Re: weak door skins
Postby jerseybud » Sun Sep 16, 2012 6:02 pm
This is the original link to the build for the truck from the link to that dtr site.
http://ramchargercentral.com/mopar-truc ... rig!!/850/
This page shows the handle reinforcements and he posted the beam reinforcement on the inside on a prior page. The lower hinge reinforcement in is there too.
jerseybud
Re: weak door skins
Postby (92)cummins » Thu Sep 20, 2012 5:58 am
alright thanks, these doors really seem to love to crack around the outside handle
92 w350 srw flatbed
79 w200 power wagon
93 D250 auto
(92)cummins
Re: weak door skins
Postby KurtzN1 » Thu Sep 27, 2012 10:50 am
If you are simply trying to reduce sound from outside, sound deadeners may do the job. There are aluminum backed ones that help control road noise.
KurtzN1
Re: weak door skins
Postby (92)cummins » Thu Sep 27, 2012 1:55 pm
no i was trying to fix how the doors are so flimsy and prevent my doors from cracking like my other dodge
92 w350 srw flatbed
79 w200 power wagon
93 D250 auto
(92)cummins
Re: weak door skins
Postby (92)cummins » Wed Oct 10, 2012 8:34 pm
i finally got around to welding some braces on the inside of my doors, just used some square tubing going across and a lil flat iron goin up and down, now theyre nice and solid like the old chevy doors
92 w350 srw flatbed
79 w200 power wagon
93 D250 auto
(92)cummins
